My A5 2.t is now consuming 1lt of oil every 700KM and the dealer has done consumption test 1 and consumption test 2 and says this is acceptable and this is normal. Does anyone else have oil burning problem with A5 2.0T? I understand that this is a widespread problem with this model 2010.:thumbsdown:
Sounds excessive. I don't have the 2.0t but either you have a leak somewhere ( check for stains on the driveway ) or you are burning large amounts maybe via piston rings ( check for blue smoke under heavy acceleration and gear changes )
there is an extensive discussion about this.
please try and find it :)
