Hello everyone! Let me start off with the car. The car is an '09 S5, it currently has 95,000 miles on it. I obtained the car at around 88.5K. It had two owners and was relatively well maintained, but needed some work. I still have a little bit more maintenance to do but for the most part it's almost as good as running stock. My plans for the vehicle are something to be elegant/classy, yet undeniably aggressive, and pretty fast. A street car with an attitude. Something people look at and go "THAT'S an Audi?" I also want the car to be stiffer, and more confidence inspiring. The potential is there in the S5, I just have a hard time feeling it coming from my last vehicle where you felt everything. This will likely be a long and slow build process, but, I'll try to post in it regularly. I'm always welcome to feed back and input as well. So, here we go.
As far as engine/power performance, I've come up with a pretty decent list. It should make the car faster than most things on the street, at least in my area, and all be pretty much easy bolt-on work.
- Intake: 034Motorsports silicon intake tube and a K&N air filter
- Exhaust: Custom 3" cat-back exhaust
- Forced induction: JHM Stage 1+ supercharger kit (once it releases)
- Fueling: JHM upgraded HPFP internals if not supplied in the Stage 1+ kit
- Transmission: JHM R-Series "5R" clutch & lightweight flywheel, JHM short throw shifter, JHM shifter linkage
- Wheels/Tires: Vorsteiner VFF-104 20" x 10" wheels, undecided on a tire compound as of yet
- Chassis rigidity: 034Motorsports density line front control arms, trans./diff./diff. carrier mounts, rear subframe inserts, aluminum X-brace
- Suspension: H&R coil overs (lowering to ~2.0" front and rear), 034Motorsports strut mounts, 034Motorsports solid rear sway bar
- Weight reduction: I don't have many ideas other than the before mentioned wheels, and a carbon fiber hood. Any ideas?
That's about it for the performance aspect of it. There will be plenty of cosmetic mods too. I'm looking into that "Xenox UK" RS5 bumper conversion kit, but I don't know what I'd do with my fog lights. It would be cool to maybe re-wire the fogs to be red LED's for the engine bay and behind the grilles. If I don't do the Xenox UK bumper, I'll do honeycombe in grilles. Some medium-to-dark window tints, light tail light tints, the P3Cars gauges, gloss black badges, and maybe a carbon fiber rear diffuser. I'll likely do the window trim from chrome to the "brilliant black" color, as well as get carbon fiber mirror cap replacements. Kind of black-out the car a bit, but hopefully in a bit of a tasteful manner.
I'll post progress as it slowly comes here, and look forward to any input/advise anyone has!
