1 - 6 of 6 Posts
cant figure out how to adjust the steering wheel?! iv read the manual and it says there should be something behind the bottom of the steering wheel to adjust it but iv searched everywhere but cant find it! can anybody help me? thanx.
The lever is actually located on the underside of the steering column toward the end of the column where it meets with the dash. Just pull the lever toward you and you'll then be able to make the adjustments.
is it a lever or like a rocker switch? and would it telescope the wheel too?
I always say a picture is worth a thousand words. :) See the "lever" I've circled in red. And yes, you will be able to make telescoping adjustments once the lever has been released.
got it TX! thanx so much!
No problem... glad to help! :)
1 - 6 of 6 Posts
