1 - 20 of 75 Posts
Discussion Starter · #2 ·
Interesting Force'... well found, you'll have to lets us know how it performs when you get it.:nerd:
It works as advertised, and is very simple to use. I turned off the "wink" DRL feature, and enabled remote top/windows operation.
Also activated flashing brake lights in S5 and Q7.
Just ordered one of these... £31 from Amazon......
WHat are the 'In-App' purchases about? Is that where they make their money with ludicrously expensive in-app purchases?
Discussion Starter · #9 ·
App is basic. Cost me $20 for the pro version. So a total of $60. :thumbsup:
Picked up one of these myself, whilst not a replacement for Vagcom as yet it's a good alternative to change some of the more basic settings, below is the list of what it do on my A5 2015 BE+ 2.0tdi
The following settings were available specifically to your vehicle using Carista:
Doors / Windows / Remote
Auto-lock doors when moving
*YES* / NO
Auto-unlock doors when key is taken out of ignition
*YES* / NO
Auto-lock trunk when moving
*YES* / NO
Beep when alarm is armed
*YES* / NO
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Unlock doors via smart key (door handle button)
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
Enable settings for opening/closing windows and sunroof
*YES* / NO
Open/close windows/sunroof/roof via long-press on remote
*YES* / NO
Close windows via long-press on remote
*YES* / NO
Open windows via long-press on remote
*YES* / NO
Close sunroof via long-press on remote
*YES* / NO
Open sunroof via long-press on remote
*YES* / NO
Sunroof action when opening via remote
SLIDE / *TILT*
Open/close only driver's window via remote or key
YES / *NO*
Open/close windows and sunroof via smart key
YES / *NO*
Close windows via smart key
*YES* / NO
Close sunroof via smart key
*YES* / NO
Open/close windows and sunroof by holding key in door lock
*YES* / NO
Open windows by holding key in door lock
*YES* / NO
Open sunroof by holding key in door lock
*YES* / NO
Close windows by holding key in door lock
*YES* / NO
Close sunroof by holding key in door lock
*YES* / NO
Open/close convertible roof via long-press on remote
YES / *NO*
Close convertible roof via long-press on remote
*YES* / NO
Open convertible roof via long-press on remote
*YES* / NO
Close convertible roof by holding key in door lock
*YES* / NO
Open convertible roof by holding key in door lock
*YES* / NO
Close convertible roof via smart key
*YES* / NO
Blink turn signals when done closing windows via remote
YES / *NO*
Enable remote control when vehicle is running and in gear
*YES* / NO
Instruments / Display / Dings
Hidden menu in dash screen via holding CAR + SETUP (req. restart)
*ENABLED* / DISABLED
Display warning about using navigation when moving
YES / *NO*
Gauge needle sweep at startup
*YES* / NO
Gauge needles lit even when headlights are off
*YES* / NO
Gauge scales lit even when headlights are off
*YES* / NO
Seat belt warning
*DISABLED* / US/CANADA STYLE / EURO STYLE 1 / EURO STYLE 2 / EURO STYLE 3
Lap timer and oil temperature in dashboard
Navigation disc eject button
Lights
Allow configuring daytime running lights via dash display
*YES* / NO
Use front LED lights as daytime running lights
YES / *NO*
Use fog lights as daytime running lights
YES / *NO*
Use high beams as daytime running lights
YES / *NO*
Use tail lights as daytime running lights
*YES* / NO
Use side marker lights as daytime running lights
*YES* / NO
Use low beams as daytime running lights
YES / *NO*
Turn off daytime running lights when parking lights are on
YES / *NO*
Turn off daytime running lights ("wink") when turn signal is on
*YES* / NO
Coming-home lights
Leaving-home lights
Use fog lights as coming-home lights
*YES* / NO
Use low beams as coming-home lights
YES / *NO*
Turn off front fog lights when high beams are on
YES / *NO*
Turn off rear fog lights when high beams are on
YES / *NO*
Cornering lights (using fog lights)
*YES* / NO
Allow configuring footwell lights
YES / *NO*
Footwell lights menu in dash display
ENABLED / *DISABLED*
Front footwell lights while driving
Rear footwell lights while driving
Flash brake lights in emergency stopping
*YES* / NO
Flash hazard lights in emergency stopping
*YES* / NO
Turn on side marker lights with headlights (US models only)
*YES* / NO
"Euro" parking lights when ignition off, turn signal on
*YES* / NO
Other
Lower passenger-side mirror when in reverse gear (req. memory seats)
*YES* / NO
Remember position when lowering passenger-side mirror in reverse gear
*YES* / NO
Obtained with Carista 2.4.0 for iOS.
Download app: https://itunes.apple.com/app/id954363569
Facebook: https://www.facebook.com/caristaapp
And this is what I got doing a diagnostic scan...
ECU info obtained with Carista 240199 for iOS:
CAN network gateway
Part #: 8R0907468N
Component: GW-BEM 4CAN-M
Coding: 80CF07FF00 (hex)
[No fault codes]
Ignition authorization
Part #: 8K0907064KE
Component: BCM2 2.0
Coding: 01B04040000000000000 (hex)
[No fault codes]
Central electronics
Part #: 8K0907063DH
Component: BCM1 1.0
Coding: 2608C0918134AFC00081480300001D0D001D438827090201000008004400020100000034000000 (hex)
[No fault codes]
Body/convenience system
Part #: 8K0907064KE
Component: BCM2 2.0
Coding: 011F068080B900808320003680000047 (hex)
[No fault codes]
Driver's door
Part #: 8T0959793P
Component: TSG FA
Coding: 011002225C01120102 (hex)
[No fault codes]
Front passenger's door
Part #: 8T0959792P
Component: TSG BF
Coding: 011002225E01120102 (hex)
[No fault codes]
Heater & air conditioning
Part #: 8K2820043BB
Component: KLIMA 3 ZONEN
Coding: 342602E000 (hex)
[No fault codes]
Steering wheel
Part #: 8K0953568Q
Component: Lenks.Modul
Coding: 000036 (hex)
[No fault codes]
Back-up camera
Part #: 8T0907441C
Component: J772__Rearview
Coding: 1020008 (decimal)
Fault codes:
02203 Audio/Video Input 1
Instrument cluster
Part #: 8T0920984K
Component: KOMBIINSTR.
Coding: 23AF000003012600010000 (hex)
[No fault codes]
Parking brake
Part #: 8K0907801N
Component: EPB-4
Coding: [none]
[No fault codes]
ABS
Part #: 8K0907379CN
Component: ESP8 front
Coding: 171DCC01 (hex)
[No fault codes]
Steering angle
[failed to connect]
Airbags
Part #: 8K0959655N
Component: AirbagVW-AU10
Coding: 30533933363030303030554A305238543053 (hex)
[No fault codes]
Engine
Part #: 03L906018JJ
Component: R4 2,0L EDC
Coding: 0A034012232401080000 (hex)
[No fault codes]
Transmission
Part #: 8K5927155L
Component: 0AW_20TDI_RdW
Coding: 000001 (hex)
[No fault codes]
Radio
Part #: 4G0035061Q
Component: Radio U DAB
Coding: 010103010000000001 (hex)
[No fault codes]
Sound system
Part #: 8T1035223A
Component: DSP Prem
Coding: [none]
[No fault codes]
Infotainment system
Part #: 8R2035666H
Component: H-BN-EU
Coding: 130101020006E1EF05808F5E00000403E40000020000000000 (hex)
Fault codes:
03157 Function Limitation because of Communication Failure
Power steering
Part #: 8K0909144J
Component: RCEPS
Coding: 100000000001 (hex)
[No fault codes]
Obtained with Carista 240199 for iOS.
Can't see functionality to reset service indicators but will keep looking and let you know..
Nice job of listing all that... sounds pretty good to me. I'm not after an all singing all dancing reader and certainly can't be bothered buying a laptop just to read my car once in a blue moon. Anything out of the ordinary I get an expert to read it... but looks like a good starter unit to start getting more familiar. :thumbup:
Ok bit of an update, at present the App doesn't let you clear service warnings
BUT
whilst playing around with my wife's S1 I managed to stumble across a known glitch in the Audi software which caused the wipers and headlight range finder to stop working. After a call to Carlista tech support (who were superb by the way) they sent me a Beta version of the software which does include the function to clear service lights etc this will be released as an update in a few weeks.
Andy ��
I just used mine yesterday and got this.
ECU info obtained with Carista 2.5 for Android:
CAN network gateway
Part #: 8T0907468F
Coding: 000003 (hex)
Fault codes:
00473 Control Module for Electric Park- / Hand Brake (J540)
Part #: 8K0907064AG
Component: BCM2 1.1
Coding: 0D0000 (hex)
[No fault codes]
Central electronics
Part #: 8K0907063D
Component: BCM1 1.0
Coding: 26001091461CAF010000080300003D3D0F1C528800010161000000 (hex)
Fault codes:
Part #: 8K0907064AG
Component: BCM2 1.1
Coding: 0106029A007A448500B000 (hex)
Fault codes:
02615 Locking fuel tank cap
02616 Unlocking fuel tank cap
Driver"s door
Part #: 8K0959793
Component: TSG FA
Coding: 011C13225E002201 (hex)
Fault codes:
02115 Lock Unit for Central Locking
Front passenger"s door
Part #: 8K0959792
Component: TSG BF
Fault codes:
00920 Heated Outside Mirror (Z4/Z5)
Driver"s seat
Part #: 8T0959760B
Component: MEM-FS
Coding: 08197B25002444111000 (hex)
[No fault codes]
Front passenger"s seat
Part #: 8T0959760B
Component: MEM-BFS
Coding: 08017025002444111000 (hex)
[No fault codes]
Part #: 8T1820043R
Coding: 46022000 (hex)
[No fault codes]
Steering wheel
Part #: 8K0953568F
Fault codes:
00886 Turn signal switches (E2)
Back-up camera
Part #: 8T0907441B
Coding: 1000008 (decimal)
[No fault codes]
Tire pressure monitor
Part #: 8K0907273A
Component: J502-RDK
Coding: 0CD154 (hex)
[No fault codes]
Instrument cluster
Part #: 8T0920980L
Coding: 8B0701000B00D705020000 (hex)
Fault codes:
Parking brake
Part #: 8K0907801C
Component: EPB Audi B8
Coding: [none]
Fault codes:
02435 Supply voltage for control module for right channel
16365 Manufacturer-specific code
00323 Vehicle Inclination Sensor (G384)
03200 Button for Electrical Parking Brake (E538)
02432 Supply voltage for left parking brake motor (V282)
02434 Supply voltage for control module for left channel
ABS
Part #: 8K0907379Q
Component: ESP8 quattro
Coding: 0F0500 (hex)
Fault codes:
Steering angle
[failed to connect]
Parking/steering assist
Part #: 8K0919475B
Component: PARKHILFE 4K
Coding: 200101 (hex)
[No fault codes]
Airbags
Part #: 8K0959655C
Coding: 303333333730303030304A55304C38543053 (hex)
[No fault codes]
Engine
Part #: 8T0907559H
Component: 3.2 SIMOS8.2
Coding: 01140009190F0121 (hex)
[Failed to check fault codes]
Transmission
Part #: 8K0927158
Component: 0B6 32 FSIUSA
Coding: 001002 (hex)
[No fault codes]
Headlight aiming
Part #: 8H0907357A
Component: AFS 1
Coding: 17 (decimal)
[No fault codes]
Infotainment display
Part #: 8T0035729D
Component: Interfacebox
Coding: 5003 (decimal)
[No fault codes]
Media player
Part #: 8T1035110C
Component: MP3-Changer
Coding: [none]
Fault codes:
02446 Disk drive mechanical malfunction
Media player
Part #: 4E0035785B
Component: SG ext.Player
Coding: [none]
[No fault codes]
Radio
Part #: 4E0910541Q
Component: TUNER EU/US/RDW
Coding: 2 (decimal)
[No fault codes]
Digital radio
Part #: 4E0910593K
Component: SDAR SIRIUS
Coding: 100 (decimal)
Fault codes:
02635 Tuner not enabled / activated
Navigation
Part #: 4E0910888F
Component: MNS US
Coding: [none]
[No fault codes]
Telephone
Part #: 4F0910336E
Component: Handyvorb2
Coding: 10900 (decimal)
[No fault codes]
Sound system
Part #: 8T0035223T
Component: DSP Prem
Coding: 020101 (hex)
[No fault codes]
Anyone with knowledge on seriousness and what it takes to fix these? Any information would be appreciated.
Discussion Starter · #20 ·
I would also like to know if you can reset the maintenance light. Seems like a hell of a deal at a tenth of the price of a vag-com.
By maintenance light do you mean fault codes?
Screen shots I just captured from my phone.
1 - 20 of 75 Posts
