1 - 8 of 8 Posts
I've seen some nice 20' wheels but offset is 45. What spacers would I neec to bring it back towards a more aggressive stance.
Current car has 15mm, 20mm spacers on 35 offset wheels which I find perfect.
Thanks in advance
With 8.5j and no spacers yes. If you are looking for the same stance, assuming the wheels you have are also 8.5j then you just need to add 10mm to your current spacers (so 25mm and 30mm).
If your current wheels are 9j, you'll be needing 30mm and 35mm spacers.
You might be better off looking for different wheels.
If my current wheels are 9j then I thought they are wider so would stick out a bit more so a spacer of a lesser amount would be needed. So reverse of what you have stated
1 - 8 of 8 Posts
