1 - 19 of 19 Posts
I received my genuine vag.com/VCDS last week, and was wondering if anyone has figured out the coding for the alarm chirp yet? :rolleyes:
If I can contribute to the vag.com community, please say so. I've got a Euro-spec A5, and for starters I'll send an auto-scan map to Ross-Tech.
Have you got an alarm chirp then ??
Oo... How ya do that then ???
Thanks :D
Sooooo, is it a Horn Confirmation or a little Chirp Please !!!
SPENDID thanks EuroDan:)
DoubleDoom..... Can you sort this for me at the Lakes please ?? :D
Eurodan, I assume from this post you are trying to turn on/off the alarm 'chirp' noise. Have you checked on your MMI menu? I have an alarm setting which allows me to turn it on and off via MMI.
Is the chirp no longer standard on 2009 vehicles, or is its availablity demographically dependent? My 2008 S5 chirps when I lock the doors with no mod. Maybe it has to do with the keyless entry option which I opted for.
We dont get it in europe as far as i am aware :confused:
Probably a EU directive about confusing migrating Swallows or something just as sensible :mad:
I'll double check to see if it is there at the moment :)
Is the Vag-com an easy system to use? I have never connected a cpter to a car and messed around with it and I am a bit worried about it... I would like to change the LED from turning off when turn signal is activated. Thanks!
Certain Euro markets do not allow alarm chirps due to noise regulations in residential areas.. I had to activate mine with Vagcom, I have not seen it as an option on the MMI
It is a small 'chirp' that is not created by the car horn...
Jason
1 - 19 of 19 Posts
