thanks for the quick reply Alex, much appreciated. any recommendations for an obd11?If you obtain a OBDeleven or Rosstech they can both clear the airbag fault.
Did you not disconnect car battery to do the install? As that usually does not throw up a code then.
Anyways hope that helps.
~Alex
