Sound like the actual flap motor maybe having intermittent issues working.
By the looks of it you've localised the front maintenance vents as the only issue yes?? What about the floor and side vents do they work as they should?
Double triple check as it's rare for all the flap motors to fail at once and if they are all then perhaps a module or coding issue.
Do you have access to a car scanner like Rosstech or OBDeleven?
A quick scan could potentially show you if there's an intermittent or opened circuit in the module or even the motors which will save you hassle indivuslly getting to.
~Alex
~Alex
