Thanks for that but I don't own any of those took it to a garage today it cost £20 quid and took him around 5 minutes was told if I hadn't turned the ignition on with it unplugged to test it befor putting it all back together it wouldn't of happened so lesson learnt never turn the ignition on if you have things unpluggedMate I am no expert but you can probably reset this with any of the OBD2 dongles (I have Carly) and or of course with VCDS. Most VAG specialists will have the VCDS system. Good luck!!!
