1 - 20 of 22 Posts
Sounds like timing chain slapping against something, whether it’s the timing chain cover or something else.
Heard of the hydraulic tensioner needing a bit of pressure and warm oil before it tightens up and that sound goes....
Still not good! Look it up and see if the sound is similar for other 3.0 but it really does sound very similar to be honest.
The fix in itself is pretty expensive too!! 😭
~Alex
Audi S5 2011 V6
Sounds like a timing chain slapping against something, whether it’s the timing chain cover or something else.
~Alex
Oh God, I am sacred now but I have booked it with VW specialist for tomorrow to see what they come out with it. they will keep the car overnight and see what the noise is for.
Don't want to spend a lot.
Audi S5 Black Edition Mrc Stage 2 no more
You've got an Audi with a 3.0 ltr supercharged engine.
If something goes wrong with the engine there are not going to be to many cheap fixes.
This is something that we all are aware of when we buy performance cars.
I hope you get it sorted and it is something like the timing chain cover, but prepare for the worst and hope for the best.
Good luck
Audi S5 2011 V6
Discussion Starter · #6 ·
Service history all upto dates. Oil changed last month and it's got 76k miles on the clock. I am not sure about the oil they used as the oil service done by a local garage. They got it off the euro car part.
Is all the service history up to date, all oil changes been done on time and with the correct oil?
What's the mileage?
How does it sound when you rev it?
Timing chain is more of a rattle.
Thinking out loud, this sounds like it could be a small split/crack in the exhaust manifold! How long does it take to stop?
Ask Ade, Redline DTM as he had the exhaust snap at the flange on the end of the cat which is attached to the manifold.
Just doesn't sound like a chain to me, more like the pffst noise you get from a leaking exhaust. After 5 mins the heat can 'seal' the split/crack in the exhaust!
Try and get the exhaust inspected underneath too and look for any signs of soot marks or when warming up, damp patches to signify a leak.
The timing chain tensioners are hydraulic working off oil pressure and can disappear with some revs. Get someone to rev it gently and see how the noise changes.
Reactions: Shuja
Audi S5 2011 V6
Discussion Starter · #8 ·
The sound normally lasts for 5 minutes or so and then doesn't come back till the next cold start. I have asked one of our work mechanics to look he said it's definitely not the timing chain.
The sound come and goes on the so it's not constant. It sort of winding and if I rev its nothing change. I will try it today to see as advice
Perhaps the timing chain runners it’s hitting shading im thinking, but the sound it’s metal on metal sound. if the exhaust was spilt or cracked I still couldn’t imagine this sort of sound unless it was loose but then it would still rattle against soemthing.
Does the OP have a solid flat head screwdriver and put the the flat part to the engine and your ear onto the handle to listen in? Could be coming from the core of the engine.
~Alex
P.S. post the resolution or even the reason for tapping pls! I’m intrigued!
Audi S5 2011 V6
Discussion Starter · #10 ·
Does the OP have a solid flat head screwdriver and put the flat part to the engine and your ear onto the handle to listen in? Could be coming from the core of the engine.
~Alex
I have just dropped the car off at the garage. The guy saw a video and he said it's not engined he thinks it exhaust something air flow but they will do a cold start tomorrow and let me know the cost and full diagnostics etc. They got a good review son to google so finger-cross.
Will keep you update with this.
You going to laugh at this but today when I started a car just an hour ago there was no sound its started just as normally do so I was double-minded about whether to take the car to the garage on not but then I realized the weather is really good and warm today. So it's definatiley to do with cold weather and a cold start.
Audi S5 2011 V6
Discussion Starter · #11 ·
Alex, The garage I have given my car in said it's not from the engine it's from the gearbox, and it could be oil. He recommends someone in Reading to look at it. So I am stuck.
he said the noise goes after 5 minutes so it seems the oil flow. so need a proper diagnosis @Alex1990
Atleast you’re getting somewhere @Shuja !
I’m hoping it’s a honestly a sorta “cheap” fix 🤞🏻🤞🏻🤞🏻
Keep us updated!
~Alex
Audi S5 2011 V6
Discussion Starter · #13 ·
Keep us updated!
~Alex
I am so confused and feel like hit my head somewhere. The first garage said gearbox they ain't got a clue doggy specialist. now the Second one is saying it's cam chain and needs to be changed but he cant does it till April and it will cost me 2k. Where can I find an honest mechanic? Seriously
And I reckon it's the exhaust! :D
The joys of cars and garages!
Whereabouts are you?
MRC in Banbury are tuning company, but specialise in Audis, they may be able to have a look?
Sorry I can only recommend MRC as I'm up in Manchester. :)
Reactions: Shuja
Booked it in for a cam chain change. The second garage said its defo a cham chain so let see the cheapest I got so far is £870.
Hopefully they’ll find the reason for the cam chain rattle while they’re at it, so it doesn’t repeat. Make sure they check the runners aswell for tell tale signs!
~Alex
Audi S5 2011 V6
Discussion Starter · #20 ·
Finally, the problem resolved. Paid £1970 including VAT got all the cham chain and apparently, there were 4 chains to replaced. The car now runs smoother than ever and seems the power is back.
the whole engine was removed even the gearbox and exhaust. It took 4 days as one of the chains which go into the fuel thing was only available from the main dealer.
If any want their cam chain to replace Pm me as I can recommend this honest garage with a good price.
1 - 20 of 22 Posts
