Hi all. I recently bought another 2013 S5 with some light front end damage and managed to pick up a pair of headlights out of a 2014 sportsback, which seem to be the adaptive type. They didn't come with the ballasts and I will be swapping over the existing ballasts. My question is will these fit or is there a harness that will allow me to activate the adaptive feature? Headlights are 8T0 941 032D & 8T0 941 031D
I mean to get them to work at all. I thought there was big diffeences on alot of things on the Adaptive vs non adaptive I think it will throw some errors mate
Sent from my SM-N960F using Tapatalk
I looked in to this and found that while some were able to get the AFS headlights to work/light, there was a persistent error on the dash and the leveling function did not work. Seems like it would be a significant undertaking to get the proper modules, coding, and wiring done for it to be 100% functional. If you can buy the whole 2014 and then source all the modules, wiring, etc. then you could probably get it to work, but that will be a ton of time, effort, and cash too most likely.
General consensus is to stick with (or source) the original type (AFS/non-AFS) headlights. AFS has 2 plugs, non-AFS has only 1.
