Anyone seen it, or has picture?
Hi Acadia,
I was down my parts department tonight to review their findings on the Homelink retrofit see
http://www.a5oc.com/forums/showthread.php/homelink-retrofit-possable-4225/index.html?p=46344#post46344
We were looking for the home link transmitter located behind the grill and in the exploded view for the 09 A5 the Camera for the advanced cruise control is shown as hidden behind the MAIN front grill, I quizzed them as to the location of the camera in the 08 and its not showing in the same place, so we figured that Audi must have relocated it from the bottom LHS.
I would get back to a GOOD local dealer and get a straight answer or go direct to Audi UK/USA and find out.
Hope that helps.
R
Yeah, I decided to do that, if they move it in the future I'm sure it will be an easy enough mod to move it on my car.Just my 2 cents, I don't think the information on the location of the adaptive cruise sensor is necessarily right. That is where it sits on the A6/A8 (bottom of grille with visible plate) and Q7 (hidden behind grille)... but I have seen 2009 A5 (Euro-spec) with the cruise sensor in the same place visible next to right fog light AND the new Q5 based on A4/A5 coming into sale soon also has the adaptive cruise visible next to the right fog light, clearly visible in pictures.
My guess is they either interpreted the homelink image wrong or Audi re-used some picture in the spare part system that didn't quite reflect A5/S5.
This does not mean they couldn't have changed its place, of course, but I am personally not confident that is necessarily the case either.
If Audi did move it and they interpreted the image right, good move, though. The sensor looks much better on the A6/A8 (or even better on Q7) hidden behind the grille.
Anyway, it is a good accessory and absolutely keep your order the same, don't worry about it.
Without seeing the picture you're looking at, I'd say that those are almost certainly the 2 central sensors for the parking plus system. The other 2 are between the fog lights and head-lamp washers.I was reading sept issue of car magazine (carmagazine.co.uk) from UK and the 2009 A5 on page 154 is stated to have adaptive cruise and it looks like 2 little cameras under license plate holder (undetected unless you look really close)
That last picture is definitely my favourite, for some inexplicable reason...Here are some pictures:
