1 - 13 of 13 Posts
I'm having a bit of a nightmare with my 2007 A5 at the moment .
In January I started getting a random ESP/ABS light - it went in for a checkup and the tech diagnosed it as a faulty ABS module.
We took the ABS module out and sent it off the ECU Testing, but they bench tested it and said it was fine. The tech then continuity tested the wiring and it checked out - there wasn't really anywhere else to go and he felt the symptoms all pointed to a faulty ABS module, so I ordered a second hand module and the plan was to fit to check but now with lockdown that's had to go on hold for the foreseeable.
I also had a wheel speed sensor go, which was replaced during the diagnostics - the faults for that are hanging about, but my cruise control is working (which is didn't when the sensor was broken) so I don't know if those codes aren't clearing because of the lack of communication with the ABS module.
I did a scan a few days ago though and noticed i've now got a lot of faults relating to the parking brake module as well which is a new development.
I'm a bit concerned various modules are going to start cacking themselves and it's just going to be chasing problems round the car from now on. Is it possible the parking brake issues are related to the ABS?
I cleared the codes and rescanned today so these are the recurring ones - any advice or comments appreciate as I'm getting a bit concerned about the old wagon.
It's going back into the garage once lockdown is over, but I'm keen to see if anyone else has had similar before (for peace of mind more than anything)? Anecdotally it seems like there's more and more getting these faults now - are the cars starting to get to an age where the electrics are going to start flaking out?
Code:
Date: 2020-04-20 17:23
  VIN: WAUZZZ8T38A01****
  Car: Audi A5
  Year: 2008
  Body type: Coupe
  Engine: CAPA 176 kW (240 HP) 3.0 l
  Mileage: 120310 KM
01 Engine
  System description: 3.0TDI EDC17
  Software number: 8K0907401
  Software version: 0009
  Hardware number: 8K0907401
  Hardware version: H01
  ODX name: EV_ECM30LTDIA5
  ODX version: A01010
  Long coding: 01140023180F0118
  Trouble codes:
  U101700 - ABS brake control module Read out DTC
  static
  static
  P161A00 - Glow plug cylinder 1 Open circuit
  static
  P161B00 - Glow plug cylinder 2 Open circuit
  static
  P161C00 - Glow plug cylinder 3 Open circuit
  static
  P161D00 - Glow plug cylinder 4 Open circuit
  static
03 Brakes
  System description: ESP8 quattro
  Software number: 8K0907379J
  Software version: 0190
  Hardware number: 8K0907379J
  Hardware version: H03
  Serial number: --------------
  Long coding: 1B4500
  Trouble codes:
  00290 - Left rear ABS wheel speed sensor Electrical error in circuit
  static
  00473 - Electronic parking brake control module -J540 Please read DTC
  static
  03265 - Suspension sensors data bus No signal/communication
  static
  00493 - ESP-Sensor unit No signal/communication
  static
04 Steering Angle Sensor
  Trouble codes:
  No trouble codes found
05 Keyless System
  System description: BCM2.01
  Software number: 8K0907289D
  Software version: 0253
  Hardware number: 8K0907289D
  Hardware version: H37
  Long coding: 071000
  Subsystems:
  System description: ELVAUDIB8
  Software number: 8K0905852A
  Software version: 0039
  Hardware version: H34
  Serial number: 0207000000504008
  Trouble codes:
  02823 - Locking requirements for Steering Column Lock not met
  static
  01330 - Comfort system central control module Please read DTC
  static
06 Passenger Seat
  System description: MEM-BFS
  Software number: 8T0959760
  Software version: 0027
  Hardware number: 8T0959760
  Hardware version: H08
  Serial number: 00001001022784
  Long coding: 08217025002444111000
  Trouble codes:
07 Display
  System description: Interfacebox  H43
  Software number: 8T0035729
  Software version: 3250
  Hardware number: 4E0035729
  Serial number: 329HX077517066
  Coding: 0005002
  Subsystems:
  System description: E0380 BedienteilH07
  Software number: 8T0919609C
  Software version: 0100
  Trouble codes:
  01043 - Control module: Incorrect Software version
  static
08 Air Conditioning
  System description: KLIMA 3 ZONEN
  Software number: 8K2820043AD
  Software version: 0123
  Hardware number: 8K2820043AD
  Hardware version: H04
  Serial number: 01060220121166
  Long coding: 2606000000
  Trouble codes:
  03037 - Rear temperature selection potentiometer Open circuit/short circuit to B+
  static
09 Central Electrics
  System description: BCM1 1.0
  Software number: 8K0907063D
  Hardware number: 8K0907279D
  Hardware version: H19
  Serial number: 00000000031424
  Long coding: 2600D0910014AF010009000300005D5D0F19038800010141000000
  Subsystems:
  System description: WWS 090807
  Software number: 8T2955119B
  Software version: 0040
  Hardware version: H11
  Serial number: SWFBIE 0000106
  Long coding: 00FD11
  System description: RLS
  Software number: 8T0955559
  Software version: 0001
  Hardware version: H12
  Serial number: 10012578
  Long coding: 02532C
  System description: E1 - LDS
  Software number: 8K0941531G
  Software version: 0070
  Hardware version: H07
  Serial number: 00000000000607070944
  Trouble codes:
0E Media Player
  System description: MP3-Changer  H42
  Software number: 8T2035110A
  Software version: 0350
  Hardware number: 8T2035110A
  Hardware version: 000
  Serial number: AUZ5ZBG4511823
  Trouble codes:
10 Parking Assistance
  System description: PARKHILFE 8K
  Software number: 8K0919475A
  Software version: 0003
  Hardware number: 8K0919475A
  Hardware version: H06
  Serial number: 46230719905946
  Long coding: 100001
  Trouble codes:
15 Airbag
  System description: AirbagVW-AU10
  Software number: 8K0959655
  Software version: 0334
  Hardware number: 8K0959655
  Hardware version: H21
  Serial number: 0038GD0875N/
  ODX name: EV_AirbaECUVWAUDI010
  ODX version: A02001
  Long coding: 30323232333030303030554A305238543053
  Trouble codes:
16 Steering Column
  System description: Lenks.Modul
  Software number: 8K0953568B
  Software version: 0011
  Hardware number: 8K0953568B
  Hardware version: H09
  Serial number: 90315GGU0001Z
  Long coding: 000016
  Subsystems:
  System description: E221 - MFL
  Software version: 0004
  Trouble codes:
  01316 - Brake control module Please read DTC
  static
17 Dashboard
  System description: KOMBIINSTR.
  Software number: 8T0920980M
  Software version: 0212
  Hardware number: 8T0920980M
  Serial number: 6C120U987
  Long coding: 2305010002002600010000
  Trouble codes:
19 Gateway
  System description: GW-BEM 4CAN-M
  Software number: 8T0907468F
  Software version: 0084
  Hardware number: 8T0907468F
  Serial number: 3200E077268069
  Long coding: 000003
  Subsystems:
  System description: J367-BDM
  Software number: 8K0915181
  Software version: 0150
  Serial number: 17002CC3230707
  Trouble codes:
  03041 - Energy management active
  Intermittent
1E Media Player 2
  System description: SG ext.Player
  Software number: 4E0035785A
  Software version: 0530
  Hardware number: 4E0035785A
  Trouble codes:
36 Driver Seat
  System description: MEM-FS
  Serial number: 00001001022434
  Long coding: 08397B25002444111000
  Trouble codes:
37 Navigation
  System description: MNS ECE  H50
  Software number: 4E0910888P
  Software version: 1060
  Hardware number: 4E0919887M
  Serial number: 333GZ077515688
  Trouble codes:
42 Driver Door
  System description: TSG FA
  Software number: 8K0959793
  Software version: 0149
  Hardware number: 8K0959793
  Serial number: 0iya �00 áa¤�
  Long coding: 011C12225E012201
  Trouble codes:
46 Comfort System
  Serial number: 0105137766
  Long coding: 011B0E80003904C1002000
  Subsystems:
  System description: DWA-Sensor
  Software number: 8K0951177
  Software version: 0030
  Hardware version: H02
  System description: LIN BACKUP HO
  Software number: 1K0951605C
  Software version: 1301
  Trouble codes:
  03123 - Terminal 30 - 2 Open circuit
  Intermittent
47 Sound System
  System description: DSP STD
  Software number: 8T0035223P
  Software version: 0250
  Hardware number: 8T0035223A
  Long coding: 010101
  Trouble codes:
  00417 - Left front DSP mid-bass speaker Open circuit
  static
  00418 - Right front DSP mid-bass speaker Open circuit
  static
52 Passenger Door
  System description: TSG BF
  Software number: 8K0959792
  Hardware number: 8K0959792
  Serial number: 0 b �00 áa¤�
  Trouble codes:
53 Parking Brake
  System description: EPB Audi B8
  Software number: 8K0907801C
  Hardware number: 8K0907801C
  Serial number: 00000000015390
  Trouble codes:
  static
55 Headlight Regulation
  System description: Dynamische LWR  H01
  Software number: 8K0907357
  Software version: 0010
  Coding: 0000002
  Trouble codes:
  static
56 Radio
  System description: TUNER EU/US/RDW H42
  Software number: 4E0910541Q
  Software version: 0620
  Hardware number: 4F0035541L
  Serial number: 336HT077514823
  Coding: 0000001
  Trouble codes:
77 Telephone
  System description: Handyvorb2  H18
  Software number: 4E0910336J
  Software version: 0810
  Hardware number: 4E0862335
  Serial number: 00000005001455
  Coding: 0010920
  Trouble codes:
Battery issues can cause all sorts of odd error code readings, definitely worth eliminating that possibility first off- even though it may seem random or unlikely.
Seems odd otherwise, unless there's a loom issue- so check for any signs of dampness inside the rear quarters where there's lots of wiring, relays & fuses too.
Good luck, as I don't think it is usual or to be expected even on an early model.
Reactions: Jeebsy
Battery was replaced in November - was still on the original battery so had it tested when it was in for a service in November which confirmed it was knackered, so hopefully that's ok. The voltage reads as fine during a scan too but i'll get it re-checked with a proper tester.
I had a feel about inside the boot side panels yesterday and they felt dry with no obvious signs of ingress but the problems did start when it felt like it was raining constantly - not sure if it's a coincidence but can't rule it out.
Feel a bit helpless as the garage is shut - hate the feeling when the car is under the weather.
Yes, frustrating at the moment..
Sounds unlikely to be your battery unless its been sat for a while (over 2 weeks)- I got one of the Ancel testers which tells you the health & status of the battery and then got a decent CTEK charger to regen & then maintain the battery, so they are the poerfect combo & peace of mind:
ANCEL BA101 12V Auto Battery Tester 100-2000 CCA 220AH AGM GEL Battery Analyzer
CTEK MXS 5.0 12v Car Bike Caravan Smart 8Step Fully Automatic Battery Charger
The CTEK devices are truly the business and extend my motorbike battery life from 2 up to 4 or even 5 years, and even managed to bring my VAN flat bettery back to like!!!! Did you get your new battery programmed to your car mate.......
Agreed Simon- the CTEK has regenerated mine, so I haven't had to change it at all- so now it';s 10 years old and yet the Ancel tester still says 'Good Battery' - no issues- Happy days!
Reactions: SimonRoma
Discussion Starter #7
It's back in the garage now - checking battery/voltage was the next plan of attack.
Tested as giving 13.3v under load, battery test showed that was good so looking at alternator now. Tech seems fairly confident that's going to be the issue.
Between that, pads and discs and a faulty EGR thermostat, plus drilling out an ABS sensor that failed, this is going to be a fun visit to the garage.
Discussion Starter #8
Alternator is in, giving 14.4 (i think), which the mechanic is happy with - he said most of the faults cleared after this, ABS and brake lights are off, but the ESP light stayed on which points to a fault with the yaw sensor (the first error which came up when all of this started).
He took the seat out, couldn't see anything wrong, but then he looked in the plug and said two of the connections had corrosion on them. Tomorrow the plan is the cut the wires and put a new plug on but looks like we're getting there.
Discussion Starter #9
Fixing the corrosion on the ESP sensor plug sorted some issues, still having problems with the rear left ABS sensor so some testing on the wiring found corroded wiring towards the rear of the car, and then there were still some residual communication issues with the ABS module - that was found to be a corroded wire in the front wing. Was road tested last night and no faults came up for the first time in five months.
Car has a clean bill of health now so going to collect it later today (with much lighter pockets).
How much lighter Jeeb?????
Discussion Starter #11 (Edited)
£1600 for parts and labour (18 hours labour all in, including five hours spent diagnosing the wiring faults, which i think is probably a bit light based on my conversations with the garage throughout the course of this).
That's alternator supplied and fitted, changing rear pads and discs, thermostat supplied and fitted, changing rear ABS wheel speed sensor (the old one needed drilled out), removing the ABS module to send away for testing, reinstalling it and bleeding the brakes, plus tracing the wiring/connection faults using ODIS.
Sorry to hear all that- it's quite a list. How come so much corrosion? Surely there has been some water ingress, although you say both the front & rear wiring has been corroded, so it's probably weather related- did you mention the car came from Ireland originally?
Discussion Starter #13
It came from Coleraine in Northern Ireland, yep - whether that would be a factor i'm not sure but my door speakers weren't working properly when i got the car - they'd basically disintegrated! There's a few bits under the car which are a bit rusty, but it's 13 years old now so I don't know how much is to be expected (this is only my second car).
I'll have a chat with the mechanic about it when I got up to collect but the ESP sensor under the seat he thinks something must have been spilled at some point or it's got wet. Not so sure about the corrosion to the wires, I had a repair done on the front wing where the wiring runs so whether something has happened then i'm not sure but it's a possibility. Have seen a few A6s on various forums etc which have had corroded wiring running under the sill covers so might just be one of these things that can happen if various unlucky stars align?
1 - 13 of 13 Posts
