1 - 6 of 6 Posts
Hi everyone can anyone help I got a a5 sportback b8 I want to fit heated seats and the body control module hasn't got the pins in the spare plug I want to know if you can use any body control module to get the pins in the spare plug cheers dean
You need to check the part number on your BCM and then check its superceded part number that supports heated seats for your car. Not any bcm will work. Once that is done and itted, coded then you will need to remove component protection for it to work fully
Either scan the car with vcds and get the part number from module 09 or physically remove it and get part number from the label.
1 - 6 of 6 Posts
