A5 Headlights Swap from UK to EU?
7.5K views 8 replies 6 participants last post by  adamjohnston82
It might not be enabled by default, but you should be able to enable it with VCDS or similar. When you select the menu option it actually just uses the headlight levelling motors to angle the lights downwards.
For the OP this wouldn't be as good as a proper conversion because the headlight range is reduced. 800 EUR sounds high for some used headlights, I was able to get one for my 2008 A5 (Xenon) for nearer ÂŁ100.
