1 - 20 of 24 Posts
Hi all, ive upgraded from the halogen to led tail lights however i have an issue with the coding. The tail light doesnt seem to light up, the brake lights work, and when i turn the tail lights on the brake light lights up dim.
Ive looked everywhere on the Internet at different coding solutions but none of them seem to work with my lights.
If someone could help me with the codung id appreciate it. Thank you
Also the harness is connected like this diagram
181276
I think there is an expert on this forum @Baas J.
New harness.
I was upgrading from halogen to RS5 lights (neon strip not led).
The harness came from Germany and I assumed they would be for left or right.
But the harnesses needed to be wired up left and right.
Hope that helps.
Discussion Starter · #12 ·
UPDATE,
all the lights are assigned to the correct channel and they all function properly, however when i do the coding it stays briefly then it resets itself to the default coding, im using obdelevn and wonder if this is an issue, i also get this error code on the comfort module,03389 as well as ir say "vehicle light malfunction " on the dashboard
181278
Hi I used vcds at the time and you needed to enter a security code ( widely available on here in the sticky section) if you didn't the car wouldn't accept the new coding.
Or sometimes you would need to do the coding a few times to get it to work.
Can't help with obdeleven I've never used it.
I know I had to change the coding to get rid of the error code.( My pc crashed and died so I can't even get to see my coding anymore)
Be careful you don't want to brick the bcm.
I've taken a few pics of the wiring but it definitely looks like a coding issue.
Just let me know if still need the pics.
Discussion Starter · #14 ·
Hi there the obdelevn adaption works like vcds, ive attached a photo of what it looks like.
181280
I know its a coding issue but im struggling to see what the issue is given all the codes work and then it resets itself. Thats the part confusing me. Im using access code 41067 which allows me to change them. This must be the right code otherwise it wouldnt change the values in the first place, im abit lost on what to look at next
Do the coding a few times and see if it changes.
I did try an app ( when pc crashed) and that wouldn't do coding even though it said it would for the paid version.
My only other advice is find someone with Ross tech ( vcds) and try that way.
There is a map in the sticky section of owners with vcds who would be willing to help for a beer or two.
Discussion Starter · #16 ·
Will give it a shot, thank you
Another thing to try would be try some simple coding like turning off the after wipe on the wipers or something simpler.
The coding is in the stickies at the top of this page.
If simple coding isn't excepted then you'll know it's the obd coder.
Use VCDS and and to forget to save after EVERY adaption, so not just when you finsihed like all ten.
did you end up having to swap any wires around? Or was it all correct? Need to get wires for mine but can’t find any that’s for uk spec car. Plus I have 2013 witch halogen and have fl led lights and all the adaptors I found are not for 2013 most say 2007-2011
1 - 20 of 24 Posts
