Not an expert on this but just wondering if there's "Component Protection" that needs to be first removed on the new door modules that you got.
"Low" line modules doesn't support folding mirrors![]()
Which door modules did you used to complete your retrofit folding mirror, just trying to avoid confusionThank you all
the mystery has been solved
Just a quick lookup in ETKA, the Drivers side Door module should be an 8T0959793G up to 2012 and an 8T0959793P from 2013^. Passenger side is 792 but same suffix as previously stated.
Thank you all
I got an facelift A5 without folding mirror when it’s out of the factory. Any idea what module will I need to make it work? Got everything except the module. ThanksThanks, folding mirror install and working
