Can anyone with a b8.5 confirm what is supposed to happen with the headlights when you turn the headlight switch to park lights (otherwise known as marker lights or side lights depending on where you are from) looks like this on the switch =00=
I've just facelifted a B8 to a B8.5, but nothing happens with the headlights when I switch it to the above, but it is a requirement in my country that is has to do something, should it be the DRLs that come on? There are no other bulbs in the headlights as far as I can tell, just the xenon headlight low/high beam (dipped/full for some of you) and the indicator/signal bulbs.
Can anyone with and 8.5 please check what happens exactly when the headlight switch is turned to =00=
Could be a VCDS issue, which I do have, just wanted to make sure what is supposed to happen, everything else on the new headlights works fine without coding, regular headlights, high/full beam, indicator/signals.
Thank you.
Thank you.
