Yep, it's called "convenience open". It's available in the central locking menu. Make sure it's set to "on".
Then, when you want the windows down, simply hold in the "unlock" key, and hey presto.
I know about the convenience opening feature where you press and hold the unlock/lock buttons to open/close
all the windows, but I remember the BMW system did as I described above - opened
only the driver's door window and then closed it again once the door was closed.
houseofg said:
Having a small garage, this sounds interesting, but how does having the window down help? So that you can crawl through Dukes of Hazzard style??
With the window open on a coupé door, you don't have to work your way past the window frame - you can lean over the open door which makes entering and leaving the car so much easier in a confined space. It was a feature that was invaluable on my 325Ci as a combination of a narrow garage and a long door made getting in and out a little difficult. And no, I don't need to go on a diet (not a lengthy crash one anyway
OK, so far it appears as though the feature is not available on the A5.
