1 - 2 of 2 Posts
Hi I had a problem with this car the other day the serpentine belt started to fray and cut through a load of wires that go to various engine sensors I had the wiring repaired but there are codes that just wont clear and then the other day it went into limp home mode, the indy its with thinks the ecu could need to be repaired or replaced has anyone had experience of this can it be repaired or replaced without using a main dealer any recommendations on who to use to repair or replace the ecu.
1 - 2 of 2 Posts
