So no software changes for you then. Your changes are probably mechanical, like replacing a hose or clip.No noticeable difference on my 08 3.2, and my vagcom mods are all still active.
Get the VAG COM HEX+CAN (USB version recommended) cable from Ross-Tech and the latest VCDS software from their site. Other versions (even from Ross-Tech) of the cable will (likely) not work because A5 needs the latest cable type.What Vag-Com do you home users use? Are there others that are as reliable and good as Ross-Tech but less expensive? I'm thinking of getting one for my A4 Avant.
I don't think there are any that are as good as Ross-Tech's.. You can find cheap interface cables on ebay, but I don't think they allow you to get into any CANBUS or MOST related modules.What Vag-Com do you home users use? Are there others that are as reliable and good as Ross-Tech but less expensive? I'm thinking of getting one for my A4 Avant.
