I have noticed that my door bottom speakers aren't working and my subwoofer too. Not too sure if it is the amp issue or actual speakers/subwoofer issue
I will try to scan my car for fault codes tomorrow and will report back, however, does anyone have any other suggestions/clues on how to check what can be causing the issue?
My car: Audi A5 3.0TDI Coupe 2008 with B&O Sound System, Audi 6-cd Changer 2G MMI High system and has an original B&O amp and an external non B&O amp and subwoofer in the boot.
Also should be noted that my AMP has taken water damage before and any sound didn't work for a day until everything dried out. (That was a year ago). If I don't find anything with scanning the car for the fault codes, should I take the door panels out first and test the speakers? Check the fuses? Or remove the amp and check the board?
Thanks!
Thanks!
