1 - 2 of 2 Posts
Engine light came on permanently with rough idle...
No other symptoms .The VCDS show there is an air leak in the intake...
What do you think?
Faults Found:
5646 - ROD - Unknown Error Code
- 00 [096]
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 139667 km
Date: 2019.11.19
Time: 13:02:24
4007 - ROD - Unknown Error Code
- 00 [232]
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Mileage: 139652 km
Date: 2019.11.19
Time: 09:26:54
4105 - ROD - Unknown Error Code
- 00 [237]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 139666 km
Date: 2019.11.19
Time: 09:42:19
4201 - ROD - Unknown Error Code
- 00 [096]
4219 - ROD - Unknown Error Code
- 00 [096]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 139750 km
Date: 2019.11.21
Time: 14:48:37
Readiness: 0000 0000
1 - 2 of 2 Posts
