Can the below issue cause the air con not to blow cold air or is this a red herring and there is a larger issue as to why the air con is not blowing cold air. From description this to me suggests that it would just affect the air flow to the "rear" of the car..???
VCDS scan:
08-Auto HVAC -- Status: Malfunction 0010
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 S HW: 8T2 820 043 S
Component: KLIMA 3 ZONEN H06 0150
Revision: D0000000 Serial number: 01311020080447
Coding: 36066000
Shop #: WSC 06325 000 00000
VCID: 428BFC09DD8FD65A83-8016
1 Fault Found:
01187 - Rear Temperature Flap Positioning Motor (V137)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 111
Mileage: 169284 km
Time Indication: 0
Date: 2019.03.08
Time: 17:28:08
Freeze Frame:
Voltage: 13.50 V
Temperature: 25.0°C
Temperature: 25.0°C
Count: 10000
Count: 9396
Bin. Bits: 01000000
Bin. Bits: 00000101
Time: 7.00 s
VCDS scan:
Coding: 36066000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 111
Mileage: 169284 km
Time Indication: 0
Date: 2019.03.08
Time: 17:28:08
Freeze Frame:
Voltage: 13.50 V
Temperature: 25.0°C
Temperature: 25.0°C
Count: 10000
Count: 9396
Bin. Bits: 01000000
Bin. Bits: 00000101
Time: 7.00 s
