I'm in the process of sourcing caliper carriers off an S5 to fit to my 3.0tdi coupe 2011.
Part numbers I assume I need are BDA979 and BDA978.
Problem I'm finding is BDA979 seem to be out of stock everywhere I've looked but I've come across part number BDA1124. Would this part be compatible with my car to be able to fit the larger front discs from a S5?
Thanks.
Not sure, doing a search on TRW shows a picture of the carrier and they look the same, but you can't relay on the picture. Also just says 30mm thickness not the diameter of the disc as this would give you your answer.
Best thing to do would be contact the seller and ask for dimensions or whether they know if it would fit the S5 345mm fron discs. :)
