1 - 7 of 7 Posts
Afternoon all , my 3.0 v6 a5 has been losing coolant since I had it 2 months ago, it also seems to be misfiring or something as its quite juddery on the motorway and sounds almost like 1 cylinder is misfiring. It's also pretty bad on fuel even if I drive like a saint I can't seem to get over 40mpg on a 20 mile run. No codes in VCDS either. Is there anything I could monitor in VCDS like injectors or something? Cheers
Sounds like the infamous knackered EGR cooler? They crack and leak coolant, sometimes into the intake. Try taking the turbo pipe off from the throttle body and/or EGR pipe (metal ribbed pipe) just after TB to check and see if it is ingesting coolant into the intake.
Discussion Starter #4
Found this........could this be an issue? Injector blow by pipe apparently.
I'm not sure. what part is that picture of?
Normally the EGR is mapped out, but you can put a blank plate in the feed pipe too, but the EGR and coolant etc will still be functioning and possibly leaking.
Discussion Starter #7
I've been told I can join the water feed up from the egr cooler and it'll bypass this.....is that accurate?
1 - 7 of 7 Posts
