https://www.audi-sport.net/xf/account/
Hi guys
Don't know where to start but wondering if some LEGEND can point me to the right direction, please.
This A5 has a digital cockpit and all of a sudden the warning lights have come up on cluster, apart from the engine management light.
On computer the only fault codes showing are
Engine control module 1
P05AF00 ative grille air shutter B stuck on
U028500 lost communication with active grille air shutter B
Air conditioning
B201000 no basic setting
B11AF07 fresh air door motor mechanical malfunction
B109207 recirculation flap motor mechanical malfunction
Door electronics driver side
B11F814 heated outside rear view mirror open circuit short circuit to ground
I've checked the battery which is showing 12.6
And the alternator showing 13.4 when running and lights on
Even connected a new battery to see of it clears the warning lights but no luck.
I've been told there could be a bad earth somewhere?
It's had a s5 diffuser put on the rear bumper with exhaust tip to cover the other side, add blu tank is more open now could it be water going in there? I don't think it will be as I've only put the diffuser 2 3 weeks ago
Please can someone help point me in the right direction thank you
Aj
Hi guys
Air conditioning
Aj
