My car won't start neither turnover, seems like the car is completely dead, battery is fully charge, sent my ECU and ECM to Flagship one to get them re-program and said the computers are fine, I had them check due to faults showing on the dash that my scanner couldn't delete, anyone having this problem, could this be a Relay Fuse problem, I need Help. Thank you
Audi 2018 S5, 2007 3.2 TT, 2010 A5
look at the safety breaker on the battery (it blows in the case of an accident and wont allow you to start the car) i had a cheap ebay one go at a round about, replaced with an OEM one and all good, you should be able to start the car if you put jumpers on the engine points as this bypasses the breaker
