1 - 6 of 6 Posts
Hi all,
Would anybody know the location of the coolant temperature sensor on the 1.8tfsi engine.
The reason I say this is I have seen videos on every other engines.
Symptoms are as follows:
Cooling fans on after 5 mins even in cold weather
Temp gauge never goes up to mid point.
It will go up if at stand for 20 mins still but then drop once moving
P-codes are as follows
P0116
P2683
Thanks in advance
Discussion Starter · #6 ·
Solved the problem. The water pump was leaking onto the loom causing a short. All the codes were relating to the same 5v circuit.
Replaced the water pump hosing and thermostat. Works perfectly now
1 - 6 of 6 Posts
