Hi All
2013 s5 tuned with mrc stage 2 quite a while ago.
Very happy with the car but recently car struggled to start up. Thought it was the battery but car has now gone into limp mode, over heating and EPC light on dash. Following is showing on the error code scan. Any ideas?
P154500 - Throttle valve control system Malfunction
static
P022100 - Throttle/Pedal Position Sensor/Switch B Range/Performance
static
P011600 - Engine Coolant Temperature Sensor 1 Circuit Range/Performance
static
P032700 - Knock Sensor 1 Circ. Low Input
Intermittent
P033200 - Knock Sensor 2 Circ. Low Input
Intermittent
P001600 - Crankshaft Position-Camshaft Position Correlation Bank 1 Sensor A
static
P001800 - Crankshaft Position-Camshaft Position Correlation Bank 2 Sensor A
Intermittent
P034600 - Camshaft Pos.Sensor Circ. (Bank2) Range/Performance
Intermittent
P034100 - Camshaft Pos.Sensor Circ. Range/Performance
Intermittent
Intermittent
static
static
static
Intermittent
Intermittent
static
Intermittent
Intermittent
Intermittent
Intermittent
