1 - 1 of 1 Posts
Hi been reading alot of info on here and looking for info please!!! I have an a5 2.0tfsi 2009 I brought the car with a problem as I wanted one for a few years .it runs great cold till it gets to 90degrees then when I get to 1500rpm epc light flashes on and off for a split second and get a judder .things I have changed and done new abs sensor,new plugs,coils,magnet,cambridge changed solenoids about new camshaft and crankshaft sensors.it throws code p0341 and p0011 so thinking timing is out/ tensioner or oil pump and pick up pipe it's done 130000miles and have a receipt saying timing chain been done.oil pressure is idle 14psi,2000rpm 30psi and 3700rpm 58psi not sure if that's low if it is must be oil pump any help would be much appreciated thanks
1 - 1 of 1 Posts
