Intake manifold flap; Bank 1
P2008 electrical malfunction
early S5's had a different intake manifold to the later, so electrical operation of the flaps, rather than vacuum as on the later ones so the fix will be different.
The code would be similar to P2004, P2005, P2006, P2007 in that either your flaps on either bank 1 or 2 are stuck open, or closed respectively.....
is it a case of manifold off to actually see what is broken, i.e. the plastic flaps have disintegrated or is it a controlling motor externally that has let the smoke out and is fubar?
Anyone had anything similar on the same age S5?
