1 - 1 of 1 Posts
I being made having some starting issues for a bit.
First it had a bad starter, which was fixed and the car started just fine again.
Starter really was bad, couldn't crank the engine anymore.
Battery was replaced before that also.
But even now still every now and then it will stall right after it starts.
Rpm just won't come up and the car stalls back out.
Don't hear any whine from the fuel pump.
Fuel filter is inside the tank on the pump, but I would assume a constant problem if any of that would be the issue.
Usually it starts the second time, but you can tell it takes a bit to get to idle rpm.
Anybody have any idea what I can look at?
1 - 1 of 1 Posts
