1 - 10 of 10 Posts
Hi. I own a A5 SB 2.0TFSI S-Tronic quattro.
The car on a cold engine seems to jump and struggle a bit, but gets better while the engine gets to op. temp.
Is this a spark error or something?
if so. Are the R8 coils a recommended upgrade for a stage 1 engine?
And what spark plugs should i get?
Best regards :)
have you done plugs on the car? how many kms on it? i put DENSO coils for an R8 on mine, (I didn’t see a difference) have you had the intake cleaned ever?
Hi. Ty for the reply.
No i havent sone anythibg yet, except for the crankshaft ventilator.
I just pcked up the car, so havent done airfilter, coils or plugs.
I will try soon to change the coils and plugs. To see if that helps.
Discussion Starter #4
the car has done 172k KM. And the engine got an overhaul at 80k.
So the oil problems are not this cuz of it.
If your engine's stock, then I would just use the stock ignition coil/spark plugs. If you're upgrading for more fuel/boost, then I would different coil/plugs with higher voltage/shorter gap.
Discussion Starter #6
My engine has a stage 1 upgrade, Has a different fuel to air mixture than stock.
looking to upgrade ro cold air intake and a different exhaust pretty soon.
And ive heard to go for a bit colder sparkplugg that normal. Any ideas?
I would ask the vendor that did your stage 1 upgade on what is required. My understanding is that only bigger turbo or larger injectors would require a colder plug with shorter gap. But it all depends on how the computer was reprogrammed.
1 - 10 of 10 Posts
