1 - 8 of 8 Posts
Hi all can someone tell me the best and cheapest obd reader/scanning tool i can buy that will let me winde the electronic handbrake piston back to change the break pads. Many thanks
You can remove the motor (2 torxe bolts) and wind the caliper back by hand if you want.
Your welcome and make sure you use grease on the motor when you reassemble to keep the water out.
Is there any particular grease to use and sorry for silly question haha I'm just learning to do things myself thanks again
I use just ordinary wheel bearing grease
Get yourself a OBDeleven. The basic model does E-Brake service. Adaptor cost £39 direct from their website inc postage.
The Pro software cost extra £21 if you plan to do coding like battery registeration and more.
You need something longterm ownership for scanning error codes
1 - 8 of 8 Posts
