Hello everyone
I have a 2009 A5 2.7 v6 auto.
Key stuck in ignition fob can’t take it out,
its seems like I’ve got no power to it, only parking brake light flashes nothing else
My computer shows the following fault codes
00456 - control module for access and start control (j518) - sporadic 004
No signal/communication
01330 - central control module for central convenience (j393) - -sporadic 004-no signal/communication
If someone could help me that’d be very much appreciated
Thanks in advance
Code 01330 is notorious for CCM issues relating to fuses.
I would go and check for all the fuses in your car first, and then move onto the CCM module itself as the cause once you’ve gone through the fuses.
Here’s a link to the fuse boxes and to help you pinpoint you in the right direction!
Let us know if you resolve it!
~Alex
~Alex
Thank you very much for your help
I will definitely try that.
if it doesn’t solve it, can it be replaced with a used CCM or does it have to be brand new and coded for the first time ?
Thank you
