1,021 - 1,040 of 1,462 Posts
I have read this thread all the way from the first post including the instructions by Congo for the update process. I am stuck on activating the maps. If I use the engineering menu for activation do I have to remove the SD card I have downloaded the maps from before using the activator SD card as with both cards in place I just get "release info cannot be read" then a prompt to abort? Can anyone help please?
The activator must be the only SD card in the unit.
Is this when using the engineering menu where I get "release info cannot be read" or for when you wait for "Nav info blocked" then insert SD card. I also saw a post where someone had to empty their 6 x CD changer before it would work. Have to say I am confused.com at the moment.
As I purchased the Firmware/maps/activator set I don't know which type of activator I have got.
hello team ... does anyone have any information about the new update for 3G BNav in 2022. ??
Hi Luke. Latest maps are 4G0060884AK and firmware needs to be K0260. I have just done mine with an SD card update set from the Satnavishop. I believe that you can make your own cards but I don't know how to do it that way and did not want to risk bricking the MMI. Only problem I had was activating the maps which was me not doing it the correct way. Hope this helps.
i know about 5.33.2 ..iam using it to, but that version is 2021/2022.... I wonder if there is any information on when the new update for 2022 will be released
As far as I know the new versions come out around December. I think the AK maps came out in Dec 21 and were called 21/22 maps. I guess they will never be right up to date like Google maps because of the time it takes to do them.
I think that the 21/22 update came out sometime in the summer, more precisely I think it was August or September, because I have had the 2021/22 update in use in my car for a long time.
You could be right there but the latest I have seen for sale are the AK ones. People on Ebay still selling the AH version and claiming them to be the latest but there has been the AJ and now the AK since. I was running 2017/2018 maps which my local Audi garage did for me and cost around ÂŁ250 just for the maps. God knows what they would have wanted for the AK's which needed the firmware taking from P0022 to K0260 as well as the map update. The ÂŁ55-99p I spent pales into insignificance in comparison.
I read on the internet that there is a version 4G0 060 884 AL or 5.34 2022 edition .... but it is nowhere to be found
I have had a quick look and all I can find is this on Wikipedia -
4G0 060 884 AL, ECE 5.34.2, Europe, 2022 Edition.
Cannot find it for sale or download anywhere and it is the East Europe version. No signs of an EUW map anywhere.
