ECS CF Intake fitted today - Audi A5 Forum & Audi S5 Forum
  • 1 Post By HTB
post #1 of 19 Old 18th October 2018, 10:08 AM Thread Starter
HTB
Quoted: 16 Post(s)
Quite pleased with the look of this and a nice supercharger sound from it. Fitted it to replace a red Forge silicone intake hose as I'd read the Forge are prone to collapsing.
Rerouted the left side fuel hose beneath the intake hose to clean up the look.
Also fitted an ECS air scoop to the front of the OEM air box.
Sent from my SM-G920F using Tapatalk
Mr.wreckless likes this.
HTB is online now
post #2 of 19 Old 19th October 2018, 09:26 AM
Looks nice. How loud did the supercharger get?
Harleymike is offline
post #3 of 19 Old 19th October 2018, 09:30 AM Thread Starter
HTB
Quoted: 16 Post(s)
The dramatic change was in going from the resonated stock intake to the Forge silicone. Changing from silicone to carbon fibre gives a bit more. I guess the rigid construction conducts the sound more. Sounds way better than stock.
HTB is online now
post #4 of 19 Old 19th October 2018, 09:57 AM
This is definitely going to be my next purchase. Have you done a stage one download?
post #5 of 19 Old 19th October 2018, 09:59 AM Thread Starter
HTB
Quoted: 16 Post(s)
Car has Revo Stage 1 ECU and TCU remap.
HTB is online now
post #6 of 19 Old 20th October 2018, 07:46 AM
Quoted: 100 Post(s)
How much was this filter option and where from?
2015 B8.5 S5 BE Coupe
ADS | Sports diff | Active Dampers | Advanced key | Sunroof | 3G+ MMi | Heated Seats
Retrofits : Adaptive Cruise Control | Adaptive Headlights | Dynamic Steering | Garage Door Opener | Hill Hold Assist | Main Beam Assist | Lane Departure Assist | Side Assist | TV Tuner | Passenger Seat memory | Heated Washer Jets
Mods : V-Dampr 195mm Drive Pulley | Eventuri | Litchfield Remap| Iabed Throttle Body | Forge chargecooler radiator | FIS-Control Module | Apple Carplay & TV
Adamantium is offline
post #7 of 19 Old 20th October 2018, 07:51 AM Thread Starter
HTB
Quoted: 16 Post(s)
What bit do you mean? The ITG foam filter or the ECS carbon fibre intake?
HTB is online now
post #8 of 19 Old 20th October 2018, 08:23 AM
Quoted: 100 Post(s)
The ECS carbon.
I did assume that the ITG came with it.
I have an eventuri ready to go on, but it was seriously expensive and am considering selling it to free up some money for something cheaper that does the same thing.
post #9 of 19 Old 20th October 2018, 08:42 AM Thread Starter
HTB
Quoted: 16 Post(s)
The ECS carbon.
Just to clarify. The air filter box is stock. I got the ITG foam reusable filter first. I think a lot of people go for K&N reusable filters.
I then replaced the factory intake hose (between the air box and engine) with a Forge red silicone hose (2nd hand eBay, £40). These are apparently prone to collapsing under load and the preferred brand of silicone hose seems to be 034 Motorsport (I think this is what MRC use).
I decided that wanted to swap out my Forge silicone for rigid carbon fibre. The only one I could find without spending shedloads on additional CF bits such as covers and airbox etc (e.g. Carbonio, Eventuri, Revo and APR) was the ECS.
You can get it from AwesomeGTI for £168.
https://www.awesomegti.com/shop-by-b...t-kit-3-0tfsi/
I also fitted an ECS intake scoop to the front of the factory airbox but this would prevent the fitting of an aftermarket cooler.
https://www.ecstuning.com/News/Audi_..._Scoops_26695/
Hope that helps.
HTB is online now
post #10 of 19 Old 13th April 2019, 12:08 AM
Ive just purchased the same intake how easy is it to fit?
jamesdebono1 is online now
post #11 of 19 Old 13th April 2019, 09:30 AM
Spensley's Avatar
Any pics of the ECS air scoop?
I'm thinking of doing this, but it doesn't fit with the APR CPS (which I may get at some point).
Spensley is offline
post #12 of 19 Old 13th April 2019, 08:34 PM
Redline_dtm1's Avatar
Quoted: 25 Post(s)
[QUOTE=HTB;1579616]Quite pleased with the look of this and a nice supercharger sound from it. Fitted it to replace a red Forge silicone intake hose as I'd read the Forge are prone to collapsing.
That looks way better than stock item and for the price is a no brainer imho. Just updated my intake system and will be ordering the front scoop anytime soon.
If everything seems to be 'under control',your not driving fast enough
Redline_dtm1 is offline
post #13 of 19 Old 18th April 2019, 09:18 PM
[quote=Redline_dtm1;1593388]
How difficult was it to fit the intake? And what does the carbon pipe clamp to the air box doesn’t have a lip on it does it??
post #14 of 19 Old 19th April 2019, 01:32 AM
Quoted: 25 Post(s)
The intake is dead easy to fit. You simply pop out the 4 plastic pop up clips above your grill,then pull the plastic slam panel up.
Once this is removed you will see 2 torx bolts which hold the original intake scoop in place.
Disconnect the scoop from the air box snorkel and replace with ecs unit.put torx screws back in an replace upper panel.
Regarding the intake pipe I imagine the carbon pipe clamps to the 2 silicone hoses. The smaller pipe clamps to the throttle body 'the bigger hose clamps to the air filter coupler.
Sent from my iPhone using Tapatalk[/QUOTE]
post #15 of 19 Old 19th April 2019, 04:14 AM
The intake is dead easy to fit. You simply pop out the 4 plastic pop up clips above your grill,then pull the plastic slam up.
[/QUOTE]
Oh it actually goes on the air filter that explains things
Does anyone know the part number one or know where to get the plastic pop clips, my car doesn’t have anything
post #16 of 19 Old 19th April 2019, 10:38 PM
Quoted: 25 Post(s)
Plastic front panel clip par number is 4D0807300 . Should be able to get them from TPS or main stealer.
post #17 of 19 Old Yesterday, 01:06 AM
Thank you been trying to find what the looked like for days just been watching videos some have said bolts clips everything
post #18 of 19 Old Yesterday, 11:37 AM
Quoted: 25 Post(s)
They cost £3.23p for 4 from TPS and they fit several different models so should be in stock
post #19 of 19 Old Today, 07:04 AM
Bargain i will have a look thanks for that
