Engine Oil Leak (2011 A5) - Audi A5 Forum & Audi S5 Forum
  • 1 Post By Smokey Joe
post #1 of 7 Old 16th April 2019, 06:14 PM Thread Starter
Good Night Everyone,
I just bought a 2011 Audi A5 Sline with a 2.0 TFSI Engine and after some checks I found out that I have a bad Oil Leak. I attached some pictures of where the leaks are. I believe it's the valve cover and oil pan gaskets. Please let me know if I'm wrong and if there are more things that need to be changed as I plan on doing the DIY myself. I bought the MAHLE Original HS54738 Engine Cylinder Head Gasket Set and MAHLE Original OS32421 Engine Oil Pan Gasket Set so far to change some of the gaskets.
Any help will be greatly appreciated. Thank you
ID:	169220   Click image for larger version
ID:	169222   Click image for larger version
ID:	169226   Click image for larger version
ID:	169228   Click image for larger version
Gsilk93 is offline
post #2 of 7 Old 20th April 2019, 07:02 PM Thread Starter
Any help anyone?
Gsilk93 is offline
post #3 of 7 Old 20th April 2019, 11:06 PM
Smokey Joe's Avatar
Quoted: 54 Post(s)
If I were you I'd do the upper leak first as it looks like this could be the culprit that's made its way down the bottom, there might not be a leak lower down.
With oil leaks like that it's always good practice to start at the top first.
SimonRoma likes this.
Smokey Joe is offline
post #4 of 7 Old 22nd April 2019, 05:52 AM Thread Starter
Thanks Smokey, I will start at the top and see whats going on. The leak by coils, what gasket will I need? Thanks for the help.
Gsilk93 is offline
post #5 of 7 Old 22nd April 2019, 11:46 AM
Smokey Joe's Avatar
Quoted: 54 Post(s)
I'm not sure without actually seeing it. I'm also not overly familiar with that engine or it's weaknesses, but I would imagine that the Cam cover would be a good place to start. Maybe someone else on the forum will be along soon to advise better than me.
post #6 of 7 Old 22nd April 2019, 09:46 PM
Quoted: 305 Post(s)
As stated you should always start at the top and work down. And I would suggest a good pressure wash of the engine to clean away all of the oil, and then run her again so that you may be able to see where it is coming from?? Good luck!
Simon
3.2 V6 FSI 2WD auto S line.
178,000km. Full leather interior.
Cobra GPS tracker system.
Wheels refurbished in gunmetal grey, bodywork polished, badges removed. Set of Brembo discs and pads fitted and calipers repainted silver. New carbon mirror covers. Replaced all 4 shocks. Fitted dipstick.
post #7 of 7 Old 27th April 2019, 10:29 AM Thread Starter
Thanks guys, will let you know how it goes...
Gsilk93 is offline
A5 2.0 T Fuel Pump Oil Leak MrWilson A5 & S5 Topics 0 23rd May 2018 02:21 AM
Major engine oil leak & water pump damage jazzciel A5 General Q&A 4 6th February 2017 08:25 AM
2011 A5 oil leak 11silverA5 New Users & Car Anticipation 1 5th April 2016 08:34 AM
Audi A5 3.0 TDI oil leak from what appears to be from back of engine Dansa5 Audi A5/S5 Tech DIY 1 14th June 2014 12:05 PM
