Green Menu - Options - Audi A5 Forum & Audi S5 Forum
  • 1 Post By crazeuk
post #1 of 11 Old 14th April 2019, 11:54 AM Thread Starter
crazeuk's Avatar
Hi Guys
I friend of mine suggested we use his OBDEleven dongle and app to switch on additional features:
a. Passenger mirror tilt when reversing.
b. Opening / closing windows when you hold the lock / unlock button. - 1. Can this be shown on the MMI menu?
I was surprised at how easy it actually was!
Anyway, we also activated the "Green Screen". - I know I need to be super careful when using it.
2. I assume it shows every option available including things that are not installed on the vehicle?
3. How do i find out exactly what options i actually do have on the vehicle?
One of the options I would really like to have is the ADS (Audi Drive Select). I found a tutorial online which talked me through the 3 options i need to change in the car menu:
i. cardevicelist -> check “Charisma” box.
ii. carbusassignment -> switch “Charisma” to “[CAN Komfort] 1/9”. - This was already selected correctly.
iii. carmenuoperation -> move “Charisma” slider to “1”.
This turned on the MMI menu option, but everything is greyed out.
4. Does this mean I simply do not have the hardware?
Additionally, there were other options I noticed which would be "fun" to have:
Tilt Angle
Compass
Is there anything else that may be fun to try?
Thanks in advance
crazeuk is offline
post #2 of 11 Old 14th April 2019, 12:24 PM
fred44nl's Avatar
1. don't think so
2. yes
3. there is a sticker on the 1st page of the service booklet
4. you will need to make changes module 09 - Cent.Elect.
AudiEnthusiasts Vag Com
http://www.audienthusiasts.com/Project_ADS.html
A5 SB 2.0 TFSI 155kW quattro Pro-Line S-tron. (16 febr. 2010 - .....)
A3 HB 2.0 FSI 110kW Pro-Line - 8P (26 jan. 2007 - 16 febr. 2010)
 MacBook Pro 14.1 - i5 - 256 GB SSD (aug. 2017) - Mojave
Original Ross-Tech cable with Vag-Com/VCDS
fred44nl is online now
post #3 of 11 Old 14th April 2019, 01:43 PM Thread Starter
crazeuk's Avatar
Originally Posted by fred44nl View Post
1. don't think so
2. yes
Hey thanks for the response.
My sticker doesnt actually show much, listed below.
For example, i know it has leathers, a MMI 3G+ etc.
4. I presume the green screen doesnt actually activate the optons, so it needs to be long coded or coded through OBDEleven,
EOA No special edition
7D1 CD changer and DVD player
4UF Driver and front passenger airbag with front passenger airbag deactivation
6XD Exterior mirrors, power-adjustable/ heated
5SJ Left exterior mirror, convex
6TS Right exterior mirror, aspherical, large viewing field
1KW Disk brakes in rear
J0P Battery 580 A (105 Ah)
1LT Disk brakes in front
1AS Electronic stability control (ESC)
1BA Standard suspension/shock absorption
3FA Without roof insert (standard roof)
5MA Decorative inserts
7X4 Park distance control in front and rear
F0A No special purpose vehicle, standard equipment / F0A
9G2 Alternator 100-150 A
0G7 Triptronic
OYG Weight range 7 installation control only, no requirement forecast
0JF Weight category front axle weight range 6
TM4 4-cyl. turbo diesel engine 2.0 l/88 kW (4V) TDI common rail base engine is TH3/TW1/TQ4/TM4/T0N
3NJ Unsplit rear seat bench, split folding backrest
8BD Halogen headlamps
U1B Instrument cluster with mph speedometer, clock, tachometer, and trip odometer
QZ7 Power Steering
1XX Leather-wrapped multifunction sports steering wheel w/ tiptronic
8Q1 Headlight range adjustment
9Q8 Multi-function display/on-board computer
BZ5 Not hot country
D92 4-cyl. turbo dies. eng. 2.0 l/105 kW 4V TDI common rail base engine is TH3/TG3/TM4/TP4/TP5
7T6 Navigation system (MID)
CD7 Alloy wheels 7.5J x 17
7K0 Without direct tire pressure monitoring system
4X3 Side airbag in front, with curtain airbag
2K1 Reinforced bumpers
3L3 Manual height adjustment for front seats
4KC Side and rear windows in heat-insulatingglass
3Y0 Without roll-up sunshade
4K4 Radio remote controlled central locking
5D7 Carrier frequency 868 MHz without panic button
1SA Without additional front underbody guard
7MG Emission standard EU5
Q1A Standard seats in front
4GG Laminated windshield with sunshield, heated
crazeuk is offline
post #4 of 11 Old 15th April 2019, 06:00 AM
Pulsarlaser's Avatar
Quoted: 51 Post(s)
Yes, correct- the comprehensive list of options can be found on this thread:
Complete VCDS - Vagcom mod list
And these were my (before mods) option codes, may come in handy (even though I'm S-Tronic & it says Tiptronic):
E4J; 7D5; 4UF; 6XL; 5SJ; 6TS; 1KW; J0Z; 1LA; 1AS; 1BE; 3FC; 5TG; 7X1; F0A; 8GR; 0G7; 0YH; 0JJ; T41; 3NZ; 8BP; U1B; X2B; 1N3; 1XX; 8Q3; 9Q4; 8Z5; D50; 7T6; F09; 7K0; 4X3; 2K7; 3L4; 4KC; 3Y0; 4K4; 5D7; 1SA; 7MG; Q1D; 4GQ
E4J = "S-line"
7D5 = DVD player
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
6XL = Exterior mirrors: with memory function, automatically dimming, electrically foldable/adjustable/heated
5SJ = Left exterior mirror: convex
6TS = Right exterior mirror: aspherical, large viewing field
1KW = Disc brakes, rear
J0Z = Battery 520 A (110 Ah)
1LA = Disc brakes, front
1AS = Electronic stabilization program (ESP)
1BE = Sports suspension/shock absorption
3FC = Pop-up sunroof, electrically adjustable
5TG = Decorative aluminium inserts, dulling
7X1 = Park distance control
F0A = No special purpose vehicle, standard equipment
8GR = Alternator 150 A
0G7 = Tiptronic
0YH = Weight range 8 installation control only, no requirement forecast
0JJ = Weight category front axle weight range 9
T41 = 6-cylinder diesel engine 3.0 L unit 059.D
3NZ = Rear seat bench unsplit, backrest split folding
8BP = Bi-functional headlight with gas discharge lamp
U1B = Instrument insert with mph speedometer, clock, tachometer and trip odometer
X2B = National sales program Great Britain
1N3 = Speed-related variable steering assist (Servotronic)
1XX = Leather trimmed multi-function sports steering wheel w/ Tiptronic
8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
9Q4 = Multi-function display/on-board computer with check control
8Z5 = Not hot country
D50 = 6-cyl. turbo dies. eng. 3.0 l/176 kW 24VV6 TDI, common rail Base engine is T41/TE1/TF1/TH1
7T6 = Navigation system (MID)
F09 = Alloy wheels 8.5J x 19
7K0 = Without tire pressure warning light
4X3 = Side air bag front with curtain air bag
2K7 = Reinforced bumpers
3L4 = Electric seat adjustment for both front seats, drivers seat with memory system
4KC = Side and rear windows in heat-insulating glass
3Y0 = Without roll-up sun screen
4K4 = Radio remote controlled central locking
5D7 = Carrier frequency 868 MHz without panic button
1SA = Without additional front underbody guard
7MG = Emission standard EU5
Q1D = Sports front seats
4GQ = Windshield in heat-insulating glass
A5 3.0 TDi quattro Coupe SE, S-line.
Deep Sea Blue, S-Tronic, 3G+MMI Nav, B&0, DAB, Bass Amp & Sub, AMI, Cruise, HBA+ auto dim RVM, Xenon Plus, LED DRL's & Fogs, 20% tints, Rear ARB & links, H&R Sports Springs.
RS5 pedals & door pulls, RS5 Body kit, BSR Custom Tuned to 333hp. FL tails & LEDs, Alcantara Starlite Elec Mem seats, custom wheel, Black Optics, 20" Alloys, S5 BBK with ceramic pads, Sunroof & folding Mirrors. Never drive faster than your guardian angel can fly..
Pulsarlaser is offline
post #5 of 11 Old 21st April 2019, 10:26 AM Thread Starter
crazeuk's Avatar
E4J = "S-line"
7D5 = DVD player
You're just making me jealous now! lol
Pulsarlaser likes this.
crazeuk is offline
post #6 of 11 Old 21st April 2019, 10:27 AM Thread Starter
crazeuk's Avatar
Does anyone have a VAG COM cable in Stevenage / Hertfordshire?
I am DYING to turn the drive select option on. (I have access to one, but its when i get home north again!
crazeuk is offline
post #7 of 11 Old 22nd April 2019, 10:42 AM
sbones's Avatar
Quoted: 69 Post(s)
Can be done with the Carista app & bluetooth obd2 adaptor
Sent from my SM-N950F using Tapatalk
sbones is offline
post #8 of 11 Old 22nd April 2019, 11:22 AM Thread Starter
crazeuk's Avatar
Oh. I didn't realise. I was having issues connecting my elm237 adapter to anything
Sent from my SM-N960F using Tapatalk
crazeuk is offline
post #9 of 11 Old 22nd April 2019, 12:17 PM
sbones's Avatar
Quoted: 69 Post(s)
Pair to phones bluetooth 1st, then carista should find it listed
sbones is offline
post #10 of 11 Old 22nd April 2019, 12:18 PM
sbones's Avatar
Quoted: 69 Post(s)
sbones is offline
post #11 of 11 Old 23rd April 2019, 12:51 PM
Thank you very much for explanation.
Kajoe is offline
Green menu options Johnaudis5 S5 General Q&A 0 24th December 2018 07:39 AM
Green menu Standard Settings Gdoene A5 General Q&A 6 31st August 2017 04:53 AM
what can you do with the green menu? dakiluxa A5 General Q&A 8 18th May 2017 11:31 PM
Open green menu please Hüseyin Sustan Audi A5/S5 Tech DIY 2 22nd February 2017 04:45 AM
Cannot activate green menu by VCDS stylobic A5 & S5 Topics 10 2nd August 2016 08:00 AM
