Cruise Control Retrofit? - Audi A5 Forum & Audi S5 Forum
  • 1 Post By V6thomas
  • 2 Post By JohnS4
post #1 of 8 Old 11th May 2019, 05:20 AM Thread Starter
V6thomas's Avatar
Quoted: 49 Post(s)
Has anyone got a guide on retrofitting the cruise control stalk to there cars?
Its something I have wanted for a while now. I know there around 50 quid to pick up.
Has anyone done this install themselves and can give me a simple breakdown?
SimonRoma likes this.
V6 go brrrr
V6thomas is offline
post #2 of 8 Old 11th May 2019, 11:13 AM
Guide here for taking the storks off so you know what’s involved.
https://www.audienthusiasts.com/Proj...eringSwap.html
Not seen a guide for this but I’m sure there must be one out there.
SimonRoma and V6thomas like this.
JohnS4 is offline
post #3 of 8 Old 12th May 2019, 06:42 AM
Quoted: 305 Post(s)
The mechanical fitting is easy as pie, but to activate it you must tell the ECU that you have one to make it work. Try VCDS or similar, my indi fitted one to my Tiguan and he said it was quite straightforward.
Simon
3.2 V6 FSI 2WD auto S line.
178,000km. Full leather interior.
Cobra GPS tracker system.
Wheels refurbished in gunmetal grey, bodywork polished, badges removed. Set of Brembo discs and pads fitted and calipers repainted silver. New carbon mirror covers. Replaced all 4 shocks. Fitted dipstick.
post #4 of 8 Old 12th May 2019, 12:56 PM Thread Starter
V6thomas's Avatar
Quoted: 49 Post(s)
Hi Mate,
I have a VCDS cable now so no problem. Is it really a direct swap! can you give me more detail? as I really want this
V6 go brrrr
V6thomas is offline
post #5 of 8 Old 12th May 2019, 04:02 PM
Quoted: 79 Post(s)
Yes direct easy swap. Remove airbag and steering wheel. Remove slip ring without moving it too much. Remove old stalks and refit everything. You will also need a new lower section of trim. Do it all with the battery disconnected. Do the coding and thats it
Audi A6 BiTdi Avant
morski is offline
post #6 of 8 Old 12th May 2019, 10:15 PM
A5JXU08's Avatar
Quoted: 101 Post(s)
You don't even need a new steering cowl, once you have removed the original you will see inside it the shape marked of what needs removing, I did mine with nothing more then a drill, file and sand paper.
2008 2.0 ltr TFSi Sport
ECS intake pipe, Pipercross filter, R8 red tops, 15mm (F) & 20mm (R) spacers, -35mm Springs, Eccentric, Poly, upper control arm bushes, Debadged and Dechromed, OEM Audi body kit (lip spoiler, side skirts, diffuser and bumper spoilers, boot lip spoiler.
Have the parts to do:-
Full RS5 Piano black trim, RS5 pedal set and foot rest, ECS oil catch can kit.
A5JXU08 is offline
post #7 of 8 Old 13th May 2019, 01:31 PM
Cudge1@aol.com's Avatar
Does anyone know any body in the Dorset area that has VCDS/vagcom that would be willing to code my cruise control on my 2008 S5?
I've done the stalk switch, reset the steering angle sensor, I'm struggling to find anyone to do the rest of it.
Pennies waiting for someone. Im Just new to the Audi world and yet to make contacts.
post #8 of 8 Old 15th May 2019, 11:02 AM
I'm in verwood if that's any good.
Simo is offline
Cruise control retrofit question Audi-Racer Audi A5/S5 Tech DIY 14 12th October 2014 12:56 AM
Cruise Control retrofit - please help with coding error chuckie A5 Performance & Mods 2 18th September 2014 07:15 AM
Cruise control retrofit around edinburgh area? Saam UK 0 10th March 2014 11:42 AM
Cruise Control - Retrofit? djc1969 A5 Performance & Mods 36 29th June 2013 03:37 AM
Retrofit Cruise control DrBaloe A5 Performance & Mods 0 3rd April 2010 04:38 AM
