Brake upgrade - Audi A5 Forum & Audi S5 Forum
 6Likes
post #1 of 46 Old 3rd March 2019, 07:14 AM Thread Starter
pfield69's Avatar
Brake upgrade
Looking for a brake upgrade.
I have 1LA 320mm disks on a t A5 3.0TDi quattro.
What's the options available?
pfield69 is offline
post #2 of 46 Old 3rd March 2019, 08:35 AM
What's your budget? There are a few options depending on how much you want to spend
Sent from my SM-G950F using Tapatalk
andrew.breakell.9 is offline
post #3 of 46 Old 3rd March 2019, 08:47 AM Thread Starter
pfield69's Avatar
looking for a cost effective solution.
Thinking second hand RS calipers if that is a solution, probably wouldn't want to remortgage to get a full on Brembo setup but if that is the best cost efficient solution that is what I'll get (just much later).
FYI making 750 Nm/ 310 BHP before the intercooler gets fitted
pfield69 is offline
post #4 of 46 Old 3rd March 2019, 10:38 AM Thread Starter
pfield69's Avatar
Thanks for the PM but I can't reply yet (Newbie).
I will look into those options
pfield69 is offline
post #5 of 46 Old 3rd March 2019, 10:43 AM
Ahh ok haha. Let me know if you need a hand with anything
post #6 of 46 Old 5th March 2019, 03:55 AM
Chestermix's Avatar
Quoted: 34 Post(s)
Im planing to upgrade my breaks as well 3.0 TDI.
I have S5 callipers with 320mm rotors at the moment.
Just waiting for RS 8 pots callipers and 365mm rotors to ne delivered.
Also RS5 rear set is on the way
A5 Coupe 3.0 TDI Quattro S-tronic 245 Black Edition
Chestermix is offline
post #7 of 46 Old 5th March 2019, 06:56 AM
Quoted: 165 Post(s)
Just out or curiosity, you didn't buy the S5 calipers did you?
Just that they are exactly the same as the standard A5 calipers, just painted in gloss black with an S5 plaque/badge.
With the rear RS5 set, you do know you have to change the rear suspension too?
A5 3.0 TDI Quattro TIP Sport
Yamaha R6 - for when the weather is good. But in the UK, this limits me to 500 miles a year!
post #8 of 46 Old 5th March 2019, 07:53 AM
Chestermix's Avatar
Quoted: 34 Post(s)
No not s5.
Proper rs5. Why i need to change suspension?
post #9 of 46 Old 5th March 2019, 08:28 AM
Quoted: 165 Post(s)
No not s5.
I'm not sure of the exact details, but the RS has a wider rear track and there is some conflict with fitting the RS rear brakes to an S or A model. There is info online and on this forum about it. Some say a spacer behind the disc works, but I'm not sure. Some say there is no point for the cost of adapting the hub/suspension to get the RS brakes to fit and opt for an aftermarket setup.
They don't just bolt straight on.
post #10 of 46 Old 5th March 2019, 08:31 AM
Chestermix's Avatar
Quoted: 34 Post(s)
The reason for them was bigger rotors.
post #11 of 46 Old 5th March 2019, 08:49 AM
You can use the Rs5 calipers and carriers and use the S4/S5 disc, that's what I've done.
post #12 of 46 Old 5th March 2019, 09:15 AM
Chestermix's Avatar
Quoted: 34 Post(s)
I got them.
ID:	168734   Click image for larger version
post #13 of 46 Old 5th March 2019, 09:19 AM
Chestermix's Avatar
Quoted: 34 Post(s)
These bad boys going to the front 390mm RS6
post #14 of 46 Old 5th March 2019, 09:23 AM
Yup those calipers with the S5 discs and you'll be fine.
These are my fronts
pfield69 likes this.
post #15 of 46 Old 5th March 2019, 09:24 AM
Chestermix's Avatar
Quoted: 34 Post(s)
These are my fronts
Callipers look massive.
Are they 365mm
post #16 of 46 Old 5th March 2019, 09:59 AM
x3me's Avatar
Quoted: 97 Post(s)
These are my fronts
They do look massive idd, from the picture i take its a pre facelift s5? But unless you are running supercharged v8 why would you want that much braking power? Or is it a track car? 😉
S5 3.0T Quattro Coupe Black Edition S-Tronic Ibis White 3G+MMI Nav, B&O, DAB, Bluetooth, AMI, 20" Gloss Black 7 Double Spokes, Elec. Folding & Auto Dim Mem Mirrors, Cruise Control, Black Leather Heated Electric Memory Seats, Xenon Plus & LED DRL's, High Beam Assist, Parking System Advanced, Panoramic Sunroof, Tinted Windows
x3me is online now
post #17 of 46 Old 5th March 2019, 12:17 PM Thread Starter
pfield69's Avatar
So am I right in saying S5 discs with RS calipers work on A5 that have 320mm front discs?
And they bolt straight on?
pfield69 is offline
post #18 of 46 Old 5th March 2019, 08:43 PM
Chestermix's Avatar
Quoted: 34 Post(s)
Originally Posted by x3me View Post
They do look massive idd, from the picture i take its a pre facelift s5? But unless you are running supercharged v8 why would you want that much braking power? Or it a track car? 😉
Id say it is a4 allroad
post #19 of 46 Old 5th March 2019, 10:17 PM
x3me's Avatar
Quoted: 97 Post(s)
I’d say it is a4 allroad
Looking back at it i think you are correct, never noticed the plastic trim around before, probably because of them huge green calipers staring at me 😄
x3me is online now
post #20 of 46 Old 5th March 2019, 10:20 PM
Smokey Joe's Avatar
Quoted: 48 Post(s)
I thought allroad too but didn't want to say in case it's some aftermarket arch kit.
Didn't want to offend anyone lol
Smokey Joe is online now
post #21 of 46 Old 6th March 2019, 02:14 AM
Pulsarlaser's Avatar
Quoted: 51 Post(s)
RS models have 380mm front rotors/ discs and a bigger Caliper & the shield ears need bending for clearance.
S4 & S5's have wider 345mm vented (front) discs, and can be an inexpensive straight swap/ upgrade as the Calipers are the same on the A5 as the S5 (S4/5 just have a badge), however the Hangers/ carriers are wider to take the 345mm vented Discs, as the A4 & A5 only have 320mm discs.
The fronts will do most of the work, so it's an option to leave the rear calipers and just add paint & discs to match the fronts if you go for grooved or drilled ones.
So with the A5 to S5 upgrade, once you have the bigger discs and carriers then yes, its bolt straight on.
A5 3.0 TDi quattro Coupe SE, S-line.
Deep Sea Blue, S-Tronic, 3G+MMI Nav, B&0, DAB, Bass Amp & Sub, AMI, Cruise, HBA+ auto dim RVM, Xenon Plus, LED DRL's & Fogs, 20% tints, Rear ARB & links, H&R Sports Springs.
RS5 pedals & door pulls, RS5 Body kit, BSR Custom Tuned to 333hp. FL tails & LEDs, Alcantara Starlite Elec Mem seats, custom wheel, Black Optics, 20" Alloys, S5 BBK with ceramic pads, Sunroof & folding Mirrors. Never drive faster than your guardian angel can fly..
Pulsarlaser is offline
post #22 of 46 Old 6th March 2019, 02:35 AM
Smokey Joe's Avatar
Quoted: 48 Post(s)
RS models have 380mm rotors/ discs and a bigger Caliper & the shield ears need bending for clearance.
S4 & S5's have 345mm (Front) discs, and can be an inexpensive straight swap/ upgrade as the Calipers are the same on the A5 as the S5 (S4/5 just have a badge), however the Hangers/ carriers are wider to take the 345mm vented Discs, as the A4 & A5 only have 320mm discs.
This is correct but.....if you want to upgrade your brakes I would seriously think twice about using the S5 setup.
Obviously it all depends on how you drive but I find that a few spirited stops in my S5 and the brakes really start to complain and fade (oem Audi pads currently).
When my pads are ready I'll try some different ones and if no improvement I'll probably change the discs/calipers for a different setup.
I don't know how bad the 320mm brakes are but I bet the 345's aren't much better.
post #23 of 46 Old 6th March 2019, 04:52 AM
Quoted: 51 Post(s)
Fair point- pads are key. I have the S5 (front) set up with 345mm vented drilled and grooved discs, and Ceramic pads all round- Hawks on the fronts & Akebono on rears, and I've also added vents in the front inner wheel arch lining that are fed by the open mesh Fog light grilles- resulting in a huge improvement from the stock A5 set-up, no complaints at all- and as I've got 333bhp to play with (same as S5) it's really important to be able to cope with the extra demand.
post #24 of 46 Old 6th March 2019, 05:07 AM
Smokey Joe's Avatar
Quoted: 48 Post(s)
Thanks. That's good to know. I was thinking of trying some ceramic pads next time. Don't get me wrong the standard S5 brakes work and work well, just seem to overheat quickly. I heard the ceramic pads are slightly kinder to the discs and produce much less brake dust which would be nice if nothing else. 👍
Pulsarlaser likes this.
post #25 of 46 Old 6th March 2019, 05:35 AM
Quoted: 165 Post(s)
There won't be a lot of difference between the A5 and S5 up front as the disc is only 25mm bigger and uses the same pads/caliper.
The rears are more of an upgrade as they are 30mm bigger and vented. But the rears require the S5 caliper and carrier too as the disc is thicker due to the ventilation.
I have Redstuff ceramic pads all round, mainly for the reduced dust than performance. I find the stopping power the same as standard. But high motorway speeds and a good press will see them complaining a bit! I've had my discs all blued, front and rear. They do stop well, but trying to stop a 1650kg car at triple digit speeds will require better than standard pads. I very nearly went for the x drilled Brembo discs, but at the time my budget only allowed for the std discs.
post #26 of 46 Old 6th March 2019, 06:01 AM
Smokey Joe's Avatar
Quoted: 48 Post(s)
Yeah the dust even after one journey is horrendous with the stock pads and plays havoc with my ocd. So definitely going to try ceramic pads next.
And as for the 25mm or 1 inch not making much difference I think my ex would strongly disagree......lol
Chestermix and pfield69 like this.
post #27 of 46 Old 6th March 2019, 06:27 AM Thread Starter
pfield69's Avatar
@Dave, I would use the RS calliper with S discs
As for fade, I have always used EBC Reds. No fade even on my turbo nos E34. I always change brake fluid to DIT 5.1 & flush every 2 years. Never had fade.
pfield69 is offline
post #28 of 46 Old 6th March 2019, 10:33 AM
mrgupe's Avatar
Anyone selling S5 carriers?
Or just info what they cost
Audi A5 3.0TDI
mrgupe is offline
post #29 of 46 Old 7th March 2019, 12:40 AM
Quoted: 165 Post(s)
They are quite rare on their own, normally come with the calipers and even discs.
TRW sell them at around 50 each.
post #30 of 46 Old 7th March 2019, 12:52 AM
max2ksr's Avatar
I've just bit the bullet and gone from OEM 320/300 on my 09 3.0tdi and gotten a full set of S5 disks, calipers and carriers for 700 from eBay. I've managed to warp pagids, brembos and OEM disks on my car. Thankfully the disks are currently being replaced under warranty by Audi as they have only been on for 2k miles.
I'm looking forward to the 345/330 combination once they are fitted.
As for rs5 brakes, you need wider set rear suspension owing to wider rear calipers and disks from the rs5 and you need at least 19" rims.
TRW sell them at about 120 each front, 80 each at the rear
Best of luck with it all
2009 A5 3.0tdi, 19" Y spoke wheels, silver, tinted windows, B&O, full Bluetooth prep, mmi2g with satnav, electronic seats, cruise control, xenon headlights, miltek cat back, ecu tune (290bhp, 587nm), led number plate lights.
Also a Triumph Sprint ST 1050
max2ksr is online now
can i upgrade my a5 brake to rs5 brake? gto_krit A5 Performance & Mods 2 9th January 2014 02:08 AM
Big Brake Upgrade 380mm A8 Direct Fit DavidB8 For Sale 6 2nd August 2012 10:33 AM
brake upgrade allawy S5 General Q&A 11 24th November 2011 01:18 PM
$30 brake upgrade+8 hours labour 1UNEEKA5 Photos & Videos 4 27th March 2011 01:07 PM
Brake upgrade frafoss A5 Performance & Mods 5 5th May 2009 06:16 AM
