Benefits of updating MMI firmware - Page 4 - Audi A5 Forum & Audi S5 Forum
post #91 of 104 Old 31st March 2015, 08:38 AM
Sorry to resurrect old thread, thought it better than starting a new one. Struggling to update my 2G High for some reason.
I'm currently running SW 5170, so assumed I didn't need to run Disc 1 that posted.
Downloaded, unrar'd and burned all the files accross for Disc 2 & 3, however when I put them into the CD loader and click update, it scans and says "metainfo2.txt cannot be found" "cannot read Metainfo". Yet when I open the CD on my PC, Metainfo2.txt is quite clearly there on both discs...I also tried Disc 1 just incase, same error with all 3 discs.
Any help please?
Thanks in advanced. Jon
Cursed is offline
post #92 of 104 Old 31st March 2015, 08:54 AM
max2ksr's Avatar
I know Im probably causing issues here, but can anyone tell me what I need to look for to update my software? Im certain Im still using the stock (2009) software. Ive got (courtesy of fleabay) the 2013 issue of the SATNAV DVD which is running fine, but I gather there are other disks needed to install the new software.
Also, VAGCOM cable? que?
again, apologies.
K
2009 A5 3.0tdi, 19" Y spoke wheels, silver, tinted windows, B&O, full Bluetooth prep, mmi2g with satnav, electronic seats, cruise control, xenon headlights, miltek cat back, ecu tune (290bhp, 587nm), led number plate lights.
Also a Triumph Sprint ST 1050
max2ksr is offline
post #93 of 104 Old 31st March 2015, 08:58 AM
again, apologies.
K
Press Media, then Setup, then go to Version, and look at the SW (top) line. The first 4 numbers are what you are after, should be SW 5170 or SW 5570 etc. Once you know which version you are running you can then look for update discs.
Cursed is offline
post #94 of 104 Old 31st March 2015, 10:00 AM
Any help please?
Got this to work by lowering the Disc write speed. Wouldn't do any updates from Disc 2, however updated from Disc 3. Now says I have 5570, however music STILL won't play over Bluetooth (The only reason i wanted to do the upgrade!!).
Any help please? I've tried playing in all settings, I assume you'd have the MMI in "Media", and select bluetooth as a Source? All i get is CD/AMI (for iPod).
Cursed is offline
post #95 of 104 Old 13th April 2015, 06:21 AM
Quoted: 83 Post(s)
For playing music over Bluetooth You would need upgrade whole system to MMI 3Gplus...
2018-?? RS5 2.9TFSI, VCDS mods, DTUK power box (500HP/700 N.m) tuned by Sportmotor
2011-2018: S5 4.2 FSI manual, OZ Racing Superturismo Le Mans wheels, Milltek exhaust
2007-2011: A5 3.0TDI Quattro Sportmotor edition, KW V2, Caractere, OZ Ultraleggera HLT 19'', chiptuning , K&N, Milltek, LED, RS5 pedals, lots of VCDS mods
post #96 of 104 Old 22nd October 2015, 01:22 AM
Petter's Avatar
If you have the 2G High, you could install a "Fiscon Basic Plus" unit that lets you play over bluetooth. At least that's what I'm planning on doing soon!
Petter is offline
post #97 of 104 Old 13th November 2015, 05:12 AM
Does anyboy have these discs still? my local audi are refusing to sell them to me as they are a "workshop tool" I have a 57 plate audi a5 with 2g mmi
samrowsell is offline
post #98 of 104 Old 31st December 2015, 12:07 AM
Hi Cursed, I want to go from 5170 to 5570 to get the 3d maps and enable me to sync my bluetooth address book. So did you only need disc 3 and was it only 10 mins as previously mentioned?
A5 Coupe 2.7 TDI
polgster is offline
post #99 of 104 Old 1st April 2016, 08:36 AM
sbones's Avatar
Quoted: 72 Post(s)
Hi I seem to be on 46.9.0 only brought car last week, just downloaded rar 1 2 3 & will burn & try thanks
sbones is offline
post #100 of 104 Old 10th April 2016, 12:18 PM
sbones's Avatar
Quoted: 72 Post(s)
Just updated mine today took a while but was easy after I ran all 3 discs & rebooting after each one I went through all 3 discs again & it picked up more available updates.
Ami still wasn't recognised in Source so removed from car unplugged / refitted then mmi found it, now all up to date & ipod works just need sat nav eject unlocking to run 2016 dvd
Sent from my SM-N910F
sbones is offline
post #101 of 104 Old 22nd June 2016, 08:33 AM
philks2's Avatar
Hi
Just updated mine using discs bought on Ebay for £30 including new sat nav maps.. and I'm a little underwhelmed.
My iphone6 has always worked on bluetooth hands free for phone, but not to play music..and that has not changed.... And the "media" button still does not recognise my iphone6 when its plugged into the lead int eh glovebox.
Anyone got any thoughts please?
PS: On sat nav (apart from more up to date maps) the only change seems to be the 3D view.
P
philks2 is offline
post #102 of 104 Old 11th August 2017, 09:35 AM
Hi mate,
I need your help as I do have an Audi Concert Radio with 0350 SW and MMI screen above as attached in both pics.
Is it up gradable?
Thanks,
ID:	149937   Click image for larger version
Wael is offline
post #103 of 104 Old 26th September 2018, 04:15 AM
Update issue
Sorry to reopen old thread, i updated my mmi on my S5 with the download link on this thread and noticed it now says S6 on the mmi screen, not to bothered, but ifs its an easy fix ill change it!
Guyfarrer6 is offline
post #104 of 104 Old 23rd December 2018, 09:25 AM
sbones's Avatar
Quoted: 72 Post(s)
Can change logo screen via green menu or carista app
Sent from my SM-N950F using Tapatalk
sbones is offline
