A5 transmission oil - Audi A5 Forum & Audi S5 Forum
  • 1 Post By julianwhitta
  • 1 Post By Dave Kwatro
post #1 of 7 Old 14th March 2019, 04:32 AM Thread Starter
A5 transmission oil
Hi Guys,
Would you please be so kind to inform me about transmission oil change of my car.
A5 2.0 tfsi quattro coupe 2011 stronic 211hp
European car.
What is the transmission oil change interval.
Currently the car is at 85k km.
What oil do i need to use?
How much litres do i need?
What do i need to change more?
Motul multi dctf is ok??
Thanks.
Razorback is offline
post #2 of 7 Old 14th March 2019, 04:49 AM
Dippy's Avatar
Quoted: 427 Post(s)
I think the first one would have been done at around 60km so you should be good until around 120km.
Current: 2015 Audi S5 sportback black edition (MRC stage 2)
Previous: 2001 Audi B5 S4 avant (modified)
Previous: Subaru Impreza WRX (wrapped around a tree)
Dippy is offline
post #3 of 7 Old 16th March 2019, 03:28 PM
julianwhitta's Avatar
Quoted: 630 Post(s)
Assuming the first change was done, of course... Worth checking the service record. If it hasn’t been done, you should absolutely get it done now.
The Motul oil should be fine. Any DSG oil that meets any of these specifications - G 052 513 , G 052 529 , G 052 726 , G 052 798 ,
G 052 171 , G 055 532 - will do the job. SWAG, FEBI and LIQUI MOLY are also options.
You’ll need 7 litres of the stuff (which is eye-wateringly expensive so, you know, be sitting down when you order it...), along with replacement filters (there’s two - one inside the box, one outside), “o” rings for both (which will probably come with the filters), a transmission pan gasket, and a new crush washer for the transmission drain plug.
There’s a very good “how-to” here:
http://audirevolution.net/forum/index.php?topic=3117.0
And a list of parts required here:
https://carltonbale.com/audi-s4s5s6s...hange-details/
Even though the second link talks about doing the gearbox on an S7, the parts required are the same - same gearbox (albeit the high-torque variant).
I’d strongly recommend you follow the directions provided in the first link, as those in the second miss out the critical bit about oil temperature. If the oil goes in cold, you’ll end up with too much when it heats up (operating temp is 38C or higher), which is BAD. The oil needs to be heated to between 30 and 50 degrees C. I racked my brain trying to figure out how to heat the oil safely, until it occurred to me that it was summer, and I could just leave the oil containers sitting in the sun for a couple of hours. Did the job nicely!
SimonRoma likes this.
2012 (fl) A5 Coupe 2.0 TFSI Quattro S-line, Lava Grey
julianwhitta is offline
post #4 of 7 Old 17th March 2019, 03:27 PM Thread Starter
Thanks. 🙂
post #5 of 7 Old 18th March 2019, 01:51 AM
Quoted: 189 Post(s)
The oil is normally 'heated' to get the correct fill level by running the engine as the gearbox internals will need to be the seame temp otherwise the oil will be cooled when you pump it in and it hits cool metal parts
Fill oil up to level plug, make sure car is level, start engine and use VCDS to check gear oil temp (or I stuck an electronic gauge on the sump before I got VCDS), run engine, hold brakes and going through R, N, D, S holding in each for about 5 secs. When temp is around 35 degrees check level, top up or level to dribble as necessary
S5 - Standard, but not for long...
2014 Audi S5 - current
2009 Audi a5 3.0TDi Tip Sport
2003 Audi A4 1.9 TDi
2004 MG ZT 190 2.5 V6
1997 BMW 328i Coupe M Sport
1994 Rover Coupe Turbo Targa top (Tomcat)
1988 Peugeot 1.9 GTi
1982 Metro 1.3s (MG herringbone/velour seats)
1984 Talbot Solara 1.6
Yamaha R6 - Gone
post #6 of 7 Old 18th March 2019, 02:57 AM
Quoted: 630 Post(s)
And this! Definitely this. Thanks, Dave.
post #7 of 7 Old 22nd April 2019, 12:30 PM Thread Starter
Hi guys,
Would you please tell what is the final drive oil?
İs it about the transmission oil?
What types of oils do i need on motul?
Thanks.
Transmission oil change for 7speed Tiptronic Help lovea50c Audi A5/S5 Tech DIY 22 14th June 2017 04:38 AM
What type of Gearbox/transmission oil is needed for 2013 Audi s5 sportback Facelift Fred87nc Audi A5/S5 Tech DIY 2 19th February 2016 10:26 PM
DIY: DSG Transmission Oil & Filter nivcogn Audi A5/S5 Tech DIY 3 23rd September 2012 01:00 PM
Please help, I drained my transmission fluid instead of my oil deankal Audi A5/S5 Tech DIY 2 21st May 2012 08:19 AM
