Has anyone managed to activate the voice control function for the cab ?
I had a quick try with someones vagcom but couldnt access the correct control section. I assume it has be deactivated due to increased noise in the cab ? the buttons on the steering wheel but when pressed comes up with a statement that the button is not used.
A5 Cab 3.0 Ltr S Line Tdi Quattro ,met grey,heated seats,folding mirrors,parking plus,tyre pressure monitor,interior light pack,bluetooth,tech pack. Collected 12-09-2009 |
Excellent timing Toothdoc - I was sat waiting for the lady wife today, browsing the handbook via MMI and stumbled accross the bits on voice activation - looks really rather nifty.
On the B7 Cab with the RNS-E DVD Navigation it was disabled by default from the factory even though (and just like the A5) there was a button for it on the steering wheel. CraigyB up in Manchester turned mine on last time. I have asked the dealer - my Cab's LH door mirror is heaterless so I'm dropping it on Friday anyway if they can turn it on - it will be worth half an hour's worth of labour if thet can get it working.
A5 2.0TDI 170 PS S-Line, Cabriolet. On PCH. Aruba Blue and Blue Roof, Black Alcantara with Silver Stitching, Heated Seats, Auto Dimming Interior Mirror, Servotronic Power Steering, Interior Light & Technology Packs, Tire Pressure Monitor, Parking Plus, Folding Mirrors, B&O, Bluetooth Phone prep, 10 spoke 18" alloys. Road Angel Pro Connected |
#3 | |
loc said it was something to do with the 5F codes. See post http://www.a5oc.com/forums/showthrea...65/index3.html (#68) Cheers
Mulski Current - A5 Cab S-Line Metallic Silver-Black Hood (2.7 TDI Multi); 19" 5 Segment; MMI3G Tech Pack; Flappy Paddles; Bluetooth; Heated Seats; Interior Light Pack; Hill Hold Assist; Cruise Control; Folding Mirrors; Dimming Mirrors; TPM; Xeon-DRLs-Rear LEDs VAG-COM'd: Non-Dimming DRLs/Voice Command/Ambient Lighting/Rear DRLs/Lap Timer/Needle Sweep/Mirror Tilt/VIM/Splashscreen/Battery Gauge/Lock Beep. 2nd Audi - A6 (2.7 TDI SE) Phantom Black; 1st Audi - A4 (1.9 TDI SE 130) Met Silver. Last edited by Mulski; 13th December 2009 at 09:17 AM. |
#4 |
Yeah, 5F is the module "location" for the MMI 3G main unit, so it would be logical voice control is coded/adapted through that. Just my speculation and, again, RNS-E example (the A3/TT/R8 navi) shows that Audi could also ship different firmwares for voice and without, so no guarantee a simple coding exists to enable voice control in MMI 3G Cabriolets.
AFAIK, VAG-COM doesn't yet know any codings for the 5F unit? Unless a very recent update does. But of course a dealer's VAS system might - and comparing codings in Coupés and Cabriolets 5F units in VAG-COM might also be helpful.
My A5 retrofit links: A5 VAG COM codes list http://a6retrofit.tripod.com/articles/a5vagcodes.html A5 "real" MMI vs. radios explained http://a6retrofit.tripod.com/articles/a4a5realmmi.html AMI parts/retrofit http://a6retrofit.tripod.com/articles/a4a5amiparts.html Homelink retrofit http://a6retrofit.tripod.com/articles/homelink.html Voice control retrofit a6retrofit.tripod.com/articles/a4a5a6voicecontrol.html Add oil dipstick a6retrofit.tripod.com/articles/a4a5oildipstick.html |
#5 |
Since the question of voice control in A5/S5 Cab seemed to pop up so often, I wrote an article about the entire topic:
Is it possible to enable voice control/speech dialogue system in an Audi cabriolet? http://a6retrofit.tripod.com/article...cecontrol.html
#6 |
Cosmic
Any luck with the voice control when the car was with the dealers ?
#7 |
Toothdoc - no, I had to cancel the appointment due to a change of diary schedule and I've since discovered that the suspected faulty mirror was caused by the pillock in the drivers seat not having the mirror switch in the centre position
![]() I have no grumbles at all with the car - so no excuse to go to the dealer....
#8 | |
....so easy done TBH ![]()
Mulski Current - A5 Cab S-Line Metallic Silver-Black Hood (2.7 TDI Multi); 19" 5 Segment; MMI3G Tech Pack; Flappy Paddles; Bluetooth; Heated Seats; Interior Light Pack; Hill Hold Assist; Cruise Control; Folding Mirrors; Dimming Mirrors; TPM; Xeon-DRLs-Rear LEDs VAG-COM'd: Non-Dimming DRLs/Voice Command/Ambient Lighting/Rear DRLs/Lap Timer/Needle Sweep/Mirror Tilt/VIM/Splashscreen/Battery Gauge/Lock Beep. 2nd Audi - A6 (2.7 TDI SE) Phantom Black; 1st Audi - A4 (1.9 TDI SE 130) Met Silver. |
#9 |
Had a reply from Audi CS re: voice control
"Thank you for your email regarding your Audi A5 and the factory fitted MMI 3G HDD satellite navigation system. I am not aware of a reason for the voice recognition to be deactivated. Your local Audi Centre is kept informed of the latest technical information by the manufacturer and will be happy to look into your enquiry and investigate further. " Spoke to my dealer who could not find that my vehicle had been fitted with this and told me that this was a factory fit module only and couldnt be retrofitted by them , not sure I am convinced especially as no one else seems to have this facility and it wasnt on any option list.
#10 |
Seems like I am shortly to have the same problem as you, I am hoping there is a solution and look forward to hearing it.
Tim
S5 Cabriolet Ordered 30.12.2009, Wk15, Collected 01.05.2010 Lifetime Economy: 4118 miles | 14.8 mpg (real) Consecutive days with the roof down: 83 Sepang Blue | Spectral Silver | S-Tronic | 20" 7 Arm Double-Spoke Alloy Wheels | Tech Pack | B&O | Advanced Key Convenience Pack | Bluetooth Interface | Heated Front Seats | Adaptive Lights | High-Beam Assist | Hill-Hold Assist Parking System Advanced | Tyre Pressure Monitor | Drive Select | Sports Diff | Damping Control |
#11 |
The definitive answer ?
"I have checked the factory specification of your vehicle, which confirms that the voice control module is not included. Unfortunately this is not available as an option on the A5 Cabriolet. " Ian Tinsley Customer Service Advisor Audi UK
#12 | |
The real question is can the A5 Coupe voice control module be fitted to the A5 cab to enable the system as it seems VAG-COM cannot do this? I can't believe the system architecture would be different given that the mic etc is fitted to both variants. If so, what work would be involved to fit the module, just a simple replacement job? There must be an audi teckie out there somewhere that could find out.... Cheers
#13 | |
#14 |
If I could find out the answer before May, I'll let you know how it works
![]() Cheers
#15 | |
But nonetheless I look forward to hearing about it!
#16 |
Found this today
. Have sent a mail to kufatec to ascertain whether it can be retro-fitted to the 2010 cab model, and if so what's involved. http://www.kufatec.de/shop/product_i...udi-A5-8T.html Cheers
#17 | |
#18 | |
As kufatec appear to have resolved this for the MMI2G along with other technology solutions, it may therefore present them a viable business case - subject to sufficient interest - to develop a solution for the MMI3G. Afterall someone has to raise the idea for any solution to materialise. Cheers
Mulski Current - A5 Cab S-Line Metallic Silver-Black Hood (2.7 TDI Multi); 19" 5 Segment; MMI3G Tech Pack; Flappy Paddles; Bluetooth; Heated Seats; Interior Light Pack; Hill Hold Assist; Cruise Control; Folding Mirrors; Dimming Mirrors; TPM; Xeon-DRLs-Rear LEDs VAG-COM'd: Non-Dimming DRLs/Voice Command/Ambient Lighting/Rear DRLs/Lap Timer/Needle Sweep/Mirror Tilt/VIM/Splashscreen/Battery Gauge/Lock Beep. 2nd Audi - A6 (2.7 TDI SE) Phantom Black; 1st Audi - A4 (1.9 TDI SE 130) Met Silver. Last edited by Mulski; 13th February 2010 at 09:50 AM. |
#19 |
That response actually says that there isn't a separate SDS module, so what is there for the Coupe is most probably also in the Cabrio - but turned off.
The previous B7 Cabrios with RNS-E DVD Navigation - were like that, the steering wheel had the button for voice control but the software was disabled in the factory. CraigyB up in Manchester enabled mine, worked a treat.
#20 |
Okay so what loc et al seem to be saying is that for MMI3G the 'voice module' is a software component embedded within the system rather than a seperate physical hardware module.
So, in order to enable it it would probably require either a software upgrade by Audi (not likely) or b) and aftermarket solution (software and/or hardware) as there appears to be no 'current' solution with VAG-COM. Cosmic; as you have already had a relationship with CraigyB (??) in Manchester would you see if he is exploring a means by which to resolve and enable the current system and in the meantime, I'll continue with kuftec and others who may be able to assist. Cheers
#21 |
Have asked the question Mulski.
Incidently CraigyB has tried to join this Forum and his application was denied, his practical insight and ability to enhance Audi systems is probaly the best in the UK - it is a shame not to have him here.
#22 |
I have seen this issue discussed before but need some clarification. My U.S. brochure clearly states that voice command is included. Is the lack of voice command limited to the euro spec A5/S5 cabs??
2010 S5 Cab./Premium+/Quartz Gray/Black-Tuscan/Nav./B&O/Sport Diff. |
#23 | ||
Mulski:
![]() However, what my article does provide, is the framework within which I believe the solution must be. What Kufatec are providing above clearly wasn't and isn't compatible with the A5 Cab. The solution is likely a VAG COM coding (if the speech software/hardware is always present and just disabled), some sort of software retrofit/hack like is available for the older RNS-E (illegal perhaps but available nevertheless), or a swap of the MMI 3G head-unit. Quote:
#24 |
I have retrofited MMI 3G into my MY2009 A4 B8. I buyed the 5f unit through ebay and the unit came from an A5 Cabrio. Now everything is working but no SDS. Now I have MMI 3G without SDS, like cabrios
![]() I'm not sure if it will be able to adapt/coding something with VCDS and enable it. A solution will be buying a 5f from a non-cabrio car. BTW I think part numbers for 5f unit in a4, a5 and a5 cab are the same, so the problem should be in the software. best regards |
#25 | |
On the A3/TT navigation device the RNS-E the part numbers for voice control enabled units are different, even if the difference there is too only in software (but not only in coding).
#26 |
#27 | |
S5 Cabriolet Ordered 30.12.2009, Wk15, Collected 01.05.2010 Lifetime Economy: 4118 miles | 14.8 mpg (real) Consecutive days with the roof down: 83 Sepang Blue | Spectral Silver | S-Tronic | 20" 7 Arm Double-Spoke Alloy Wheels | Tech Pack | B&O | Advanced Key Convenience Pack | Bluetooth Interface | Heated Front Seats | Adaptive Lights | High-Beam Assist | Hill-Hold Assist Parking System Advanced | Tyre Pressure Monitor | Drive Select | Sports Diff | Damping Control Last edited by shmee150; 21st February 2010 at 07:41 AM. |
#28 |
Great stuff javii, again thanks.
I updated it to my signature's VAG COM page too so it is easily found in the future as well.
#29 | ||
![]() Thanks guys and loc, thank you for your patience and perseverance in helping us cab owners obtain a solution to enable SDS - really appreciated. Cheers
#30 | |
![5 1 116[1]](images/smilies/5_1_116[1].gif)
