Hello...
Some one have an idea where is the adress with the vag com to unlock the "video in motion" with the new MMI 3G??? Thanks alot... |
i doubt it will be as simple as a vag com change.
SOLD June 2010: Audi S5 Phantom Black | Pearl Silver seats | Silver Headlining | Carbon Inlay| B & O | Nav Plus | TV | Bluetooth | Comfort Pack | Heated F/R seats | Parking Plus | Hill-hold assist | Advanced Key | Cruise | Storage Modifications Milltek Cat back exhaust (non-res) | 15mm spacers | KW V2 coilovers (lowered f: 25mm, r: 20mm) | Sportec pedals Misc adjustments DRLs no longer dim with indicators| DRLS no longer dim on side light setting | MMI 4690 to 5570 | TV in motion unlocked. |
#3 |
I talked to Kufatec about this and they just kept repeating that I had to send the main unit to them
Now with Swissvax Divine on the car! 2009 A5 3.0TDI S-line quattro | Ice Silver | Black S5-interior | Carbon Atlas inlays | Panorama glass roof | MMI 3G | B&O | APS w/ camera | KW Variant 3 | TTS steering wheel | Advanced Key/Keyless | El. memory S5-seats - heated | Hold Assist | Cruise Control | El. sunshade | Xenon plus | MTM 310hp kit | Remus sport exhaust | Caractere bodykit | 20" Petrol Traviata wheels |
#4 |
With 2g Kufatec send out a piece of kit you plugin and it makes the changes. 3g is still new so they are still learning it.
#5 |
I found out that the video on motion is a simple VAG-COM mod... Channel 05 is the place to edit, but RossTech hasn't documented that channel yet. So if anyone have more information or tried the different settings, please let me know.
#6 |
Hi....
Kufatec activate the video in motion on my A5 when i go to Kufatec for the coding of the rear led.... Simply with their computer on the VAGCOM.... |
#7 |
what is video in motion?
#8 |
#9 |
It is known thing, but I don't know, what is the security code for enabling changing the correct channel.
A5 3.0TDI Quattro, KW V2, Caractere (front and boot lip), OZ Ultraleggera HLT 9x19'' ET30, chiptuning, K&N filter, Milltek exhaust, LED rear lights, RS5 pedals, all known VCDS mods (Auxilliary ventilation, ADS, Memory of the seat in the key, etc.) |
#10 |
Isn't that kind of dangerous...to be watching DVDs while you are supposed to be driving?
#11 |
For the passenger it's ok
#12 |
do you have to put the DVD in the trunk? Do you get the audio from the DVD as well?? How'd you do it?
-- '09 PBP S5 -- |
#13 |
#14 |
Yeah, that's cool..
We need to figure out the coding so that we can unlock it with our VAGCOM as well.
-- '09 PBP S5 -- |
#15 |
Yes, if anyone have this information - please share!
#16 |
Do you put the Navigation DVD in the trunk like us, or do you put it in that front slot as well???
Does anybody know if we put a DVD into the 6 disc changer, it would read it as a DVD and play through the screen? Or do we need to put it in the trunk DVD slot? I'll check out Channel 05 if somebody verifys that you can put a DVD into the 6 disc changer...
-- '09 PBP S5 -- |
#17 |
Hi...the naviguation is on the hard drive,in the trunk...the 6cd charger is only for Cd or Cd Mp3...not for DVD....Dvd only on the front slot....
#18 | |
Where is your 6 disc changer? You don't use a disc for the navigation map content?
-- '09 PBP S5 -- |
#19 | |
The navigation DVD is in the DVD player in the boot (which isnt linked to the TV so cant be used for that).
#20 |
So you put the DVDs in the dash slot? How'd you unlock the TV in motion?
-- '09 PBP S5 -- |
#21 |
try this website. audi-portal.com
navplus.com has a post about VIM and this guy has seem to been helping everyone unlock the coding. I hope this helps!
2009 Audi S5 Ibis White/Pearl Silver Alcantara A5 S-line Grill Unitronic Flash E-codes AWE Black Chrome Exhaust w/ Downpipes Stasis Rear Sway KW.v2 Dpe SP16 Step lip 20x10 Eurogear Carbon Splitters & Rear Valence |
#22 | |
SO IT CAN BE DONE! We just need to figure out how... Kufatec just sells the bungle that is like a one-time use reprogrammer... somebody that has used it could tell us the differences?
-- '09 PBP S5 -- |
#23 |
http://audiforum.us/mmi/9663-vim.html
Thats actually not 100% true. From what i have read and spoke to them about is they actually do connect with you live via phone and computer in order to read the numbers needed in order to unlock for you specifically. I was going to do it since the link shown shows positive results but other things came up now. I know for 2g we need a external dvd drive as well. Dont want to start a forum battle but that site does have some good information as well.
#24 |
You dont put DVDs in the dash slot. Its not a DVD player but a 6 CD changer. There are two AUX ports that you can add a DVD player to if you wish.
#25 |
Take a good look. the picture is from the 09 model. I have a feb 2009 model.. and the slot is indeed for a DVD or (MP3)CD.
VAG-com unlock? I thougth it was/is a mithe...
2009 S5 Tiptronic | Custom color: Porsche DarkOliveGreen | Mustang interior | Carbon Atlas inlays | B&O |Technology | DVD Nav new MMI | VAG-Com change: Video In Motion activated + LED Tail (always on) + parking mirror activated |
#26 |
how can i unlock VIM in MM 3G- VSDC????
#27 |
At the moment the only two publicly known ways (as far as I can tell) are these, for both MMI 2G and 3G TV/video in motion:
1) Buy a MMI 2G or MMI 3G dongle from Kufatec (MMI 3G dongle also releases DVD playback while driving), kufatec.de. 2) Or pay to audi-portal.com (http://www.audi-portal.com/en/retrof...ricks_001.html) for them to remote connect to your computer and do it via VAG COM. You need to have VAG COM cable connected to the car, of course. The latter tells us that it is possible to with VAG COM and both Kufatec dongle and audi-portal.com actually "just" code the car some way that we probably could do ourselves... if we knew how. Unfortunately the one party that might have this info and a business-case to release it is Ross-Tech (makers of VAG COM), who do not want to release the info - if their employees public comment is correct - for liability reasons (so that they won't be sued when somebody crashes watching video). Others that know have a business-reason to not tell us... so until someone who knows spills the beans, personally I would sit tight or maybe go with the Kufatec dongle because Kufatec is an older establishment and thus I would better know what I am getting. Everyone is free to choose of course! Whether or not it is right for people to withhold the information, that is a debate I don't want to have. Nor do I expect the info to come out any time soon, so don't wait for it unless you are prepared to wait forever. MMI 2G is really six years old now and that info still isn't in the public, I doubt MMI 3G info will come out any sooner unless someone in the know decides to tell. Note: Unlocking this might be dangerous and/or illegal in your country.
My A5 retrofit links: A5 VAG COM codes list http://a6retrofit.tripod.com/articles/a5vagcodes.html A5 "real" MMI vs. radios explained http://a6retrofit.tripod.com/articles/a4a5realmmi.html AMI parts/retrofit http://a6retrofit.tripod.com/articles/a4a5amiparts.html Homelink retrofit http://a6retrofit.tripod.com/articles/homelink.html Voice control retrofit a6retrofit.tripod.com/articles/a4a5a6voicecontrol.html Add oil dipstick a6retrofit.tripod.com/articles/a4a5oildipstick.html Last edited by loc; 8th July 2009 at 10:26 AM. |
#28 |
What do you know, somebody came up with a free solution for both MMI 2G and 3G, or so they claim:
http://www.trick77.com/2009/07/18/en...s-vag-com-mmi/
My A5 retrofit links: A5 VAG COM codes list http://a6retrofit.tripod.com/articles/a5vagcodes.html A5 "real" MMI vs. radios explained http://a6retrofit.tripod.com/articles/a4a5realmmi.html AMI parts/retrofit http://a6retrofit.tripod.com/articles/a4a5amiparts.html Homelink retrofit http://a6retrofit.tripod.com/articles/homelink.html Voice control retrofit a6retrofit.tripod.com/articles/a4a5a6voicecontrol.html Add oil dipstick a6retrofit.tripod.com/articles/a4a5oildipstick.html |
#29 |
Just for future reference, I also collected this info here:
Notes on unlocking MMI 2G/3G video while driving http://a6retrofit.tripod.com/article...oinmotion.html
#30 |
MMI VIM login-code generator Windows application
http://www.trick77.com/2009/07/22/mm...s-application/ http://www.trick77.com/wp-content/up...IMGenSetup.msi http://www.trick77.com/2009/07/18/en...s-vag-com-mmi/ http://www.trick77.com/tools/mmi2g_vimcode.php http://www.trick77.com/tools/mmi3g_vimcode.php I have try it myself, and i can login in 07 Head Unit - 10 - Adaptation channel 63 to modify the value to 255 |
