More reasons to get your VAG COM cable guys...
VAG COM adaptation to change Audi Drive Select default - here: See: Changing default Audi Drive Select mode http://a6retrofit.tripod.com/articles/a5vagcodes.html Thanks to schneidfried!
My A5 retrofit links: A5 VAG COM codes list http://a6retrofit.tripod.com/articles/a5vagcodes.html A5 "real" MMI vs. radios explained http://a6retrofit.tripod.com/articles/a4a5realmmi.html AMI parts/retrofit http://a6retrofit.tripod.com/articles/a4a5amiparts.html Homelink retrofit http://a6retrofit.tripod.com/articles/homelink.html Voice control retrofit a6retrofit.tripod.com/articles/a4a5a6voicecontrol.html Add oil dipstick a6retrofit.tripod.com/articles/a4a5oildipstick.html |
Thanks as always Loc, and schneidfried - Looks like I'm back in the car this weekend.
Currently: S5 Cabriolet, Phantom Black, B&O Sound System, DAB Radio, Phone prep high, Tech' pack with ACC, Parking Advanced, TPM, Advanced Key, Adaptive Lights,Comfort Pack, Heated Front Seats, Drive Select full, & Sports Diff. |
#3 | |
but also low economy and high fuel costs...The list of things to do when my car arrives is beginning to get rather scary!
S5 Cabriolet Ordered 30.12.2009, Wk15, Collected 01.05.2010 Lifetime Economy: 4118 miles | 14.8 mpg (real) Consecutive days with the roof down: 83 Sepang Blue | Spectral Silver | S-Tronic | 20" 7 Arm Double-Spoke Alloy Wheels | Tech Pack | B&O | Advanced Key Convenience Pack | Bluetooth Interface | Heated Front Seats | Adaptive Lights | High-Beam Assist | Hill-Hold Assist Parking System Advanced | Tyre Pressure Monitor | Drive Select | Sports Diff | Damping Control |
#4 |
Can not wait for my cable to arrive! Will be one day of (re)programming I am afraid............and let's hope the car will start afterwards!
NL-S5 Cabrio Brilliant Black|Waxoil|Mustang Brown leather|Comfort seats/ventilation|Neck-heating|Heated front/rear seats|Memory seats/mirrors|Silver Headlining|RVS Inlay|B&O|MMI 3G High|Nav Plus|AMI|Freecom XXS 320Gb HDD|DVD|TV/Radio|Bluetooth Plus|Xenon Plus|LED rear|Adaptive Light|High-Beam assist|Light Pack|Parking Advanced|Advanced Key|Adaptive Cruise|Side Assist|19" RS6 wheels (PQ6)|TPM|Dynamic Steering/Suspension|Sports differential|Hold assist|HomeLink|Track & Trace|Ski-bag|Storage Pack |
#5 |
For cars with no Carisma switch:
As I have found last year, you can enable carisma individual settings in MMI for engine only (you can choose comfort/dynamic/auto) in cars with no Carisma switch, dynamic steering and magnetic suspension. After coding 09 - Central electric and 17- Instruments for Carisma (if someone will be interested I put the coding changes, it is not complete in coding helper), and when you change Adaptation channels 63 - 66 to 4 - individual, you can use carisma individual settings for engine in MMI. I have it on my car now (5 mins or so), but I haven't test it yet in driving conditions. Of course in this case you will have DTC in module 09 like this: "no carisma switch found", but who cares, when it is always set to Individual ...
A5 3.0TDI Quattro, KW V2, Caractere (front and boot lip), OZ Ultraleggera HLT 9x19'' ET30, chiptuning, K&N filter, Milltek exhaust, LED rear lights, RS5 pedals, all known VCDS mods (Auxilliary ventilation, ADS, Memory of the seat in the key, etc.) |
#6 | |
H1 C99 - "Carisma Switch"? Excuse my ignorance but can you enlighten us. Am I assuming you mean that you can set the engine settings to Comfort/Dynamic/Auto mode via the MMI for those of us without this option at the time of ordering? If, so can you switch the MMI settings at will or do you need to reset it every time via VAG-COM. Cheers
Mulski Current - A5 Cab S-Line Metallic Silver-Black Hood (2.7 TDI Multi); 19" 5 Segment; MMI3G Tech Pack; Flappy Paddles; Bluetooth; Heated Seats; Interior Light Pack; Hill Hold Assist; Cruise Control; Folding Mirrors; Dimming Mirrors; TPM; Xeon-DRLs-Rear LEDs VAG-COM'd: Non-Dimming DRLs/Voice Command/Ambient Lighting/Rear DRLs/Lap Timer/Needle Sweep/Mirror Tilt/VIM/Splashscreen/Battery Gauge/Lock Beep. 2nd Audi - A6 (2.7 TDI SE) Phantom Black; 1st Audi - A4 (1.9 TDI SE 130) Met Silver. |
#7 |
a very interesting mod. which I will put in shortly.
another one that has to be set every day, is the MIX of the mp3-jukebox. anybody found this out yet ??
A5 SB 2.0 TFSI Q PL S-tron. (16 febr. 2010 - .....) A3 HB 2.0 FSI - 8P (26 jan. 2007 - 16 febr. 2010) MacBook Air 2.1 - 2.13 GHz - 128 Gb SSD (oct.2009) |
#8 | |
You can have the same Carisma individual settings for engine in MMI as the car with this option. Works the same way. No need to reset it via VAG-COM every time because it will be at Individual settings after adaptation of channels 63-66, it means Audi Drive Select default are set to Individual so it will be always in individual mode after Ignition on, so you can control it through MMI settings. You can also buy the switch and retrofit it, but in my point of view, I don't need it.
#9 |
Just coded the car and it works as advertised. It is nice not having to keep changing the default at start-up.
2010 S5: Meteor Grey || Tuscan Brown |
#10 | |
- Zee His arrived 25 Feb 2010: 2010 Audi S5 | Sprint Blue | Alcantara | Black Optic | B&O | BBS | Eibach | B&B | Stasis | H&R | K&N | PIAA | E-codes | OEM mods | Tint Hers arrived 29 Dec 2009: 2010 VW Golf | TDI | Black | Black | OEM Mods | Tint Been there, Done that: Silverstone F1 circuit, Spa Francorchamps, Donnington Park, Virgina International Raceway and the mighty Nürburgring |
#11 |
So if I have drive select and non-nav cars, can I change the Indiviual settings and lock it in? I know we don't have an Individual button per say, but maybe the function is still buried in vagcom somewhere.
Edit: will this coding make real Drive Select buttons useless? Or will it lock the engine settings to Dynamic as I go to Comfort or Auto? If that's true, that serves me just fine. Last edited by Ryan_T; 7th March 2010 at 11:42 AM. |
#12 | |
I also don't have an individual button because based in Cyprus there aren't even any maps for the sat/nav so I didn't order it ![]()
Audi A5 Coupe 2.0TFSi Quattro S-tronic,Quartz grey,Star silver leather, Drive select damping and steering, Xenons, sound system, Bluetooth, Comfort key, parking gizmo, folding mirrors with high-beam-me-up- Scotty assistance, rear sunblind thingy and a few other "toys".... Ordered 23rd December 2009 Build week: 7 Delivered April 12th! |
#13 |
This has blown me away. It works. I'm staggered.
The steps above are absolutely accurate for those of us with 3G MMI except you need to do one extra thing: for MMI 3G go to the secret menu, Select "Car" menu, Select “cardevicelist”, scroll down and check Carisma. Now, go back, and still in the "Car" menu, select “carmenuoperation”. Scroll down to Carisma. It will be set to 0 you will change it to 1 then push the scroll wheel to set it. Restart MMI. Follow the other VAGCOM changes, and you are good to go. I have the option to choose Comfort, Auto or Dynamic. Superb mod - not driven the car, but started it with no error codes. I'm travelling to New Orleans for 2 weeks, but will try out the new settings when I get back. Good stuff!
- Zee His arrived 25 Feb 2010: 2010 Audi S5 | Sprint Blue | Alcantara | Black Optic | B&O | BBS | Eibach | B&B | Stasis | H&R | K&N | PIAA | E-codes | OEM mods | Tint Hers arrived 29 Dec 2009: 2010 VW Golf | TDI | Black | Black | OEM Mods | Tint Been there, Done that: Silverstone F1 circuit, Spa Francorchamps, Donnington Park, Virgina International Raceway and the mighty Nürburgring Last edited by zee007; 7th March 2010 at 05:31 PM. |
#14 |
If you don't have ADS (Drive Select), does that mean all you're doing with the Individual is the engine settings? Cause no matter what you do, it's only changing the tranny/engine. settings.
#15 |
Correct - tranny and engine but also steering firmness.
- Zee His arrived 25 Feb 2010: 2010 Audi S5 | Sprint Blue | Alcantara | Black Optic | B&O | BBS | Eibach | B&B | Stasis | H&R | K&N | PIAA | E-codes | OEM mods | Tint Hers arrived 29 Dec 2009: 2010 VW Golf | TDI | Black | Black | OEM Mods | Tint Been there, Done that: Silverstone F1 circuit, Spa Francorchamps, Donnington Park, Virgina International Raceway and the mighty Nürburgring Last edited by zee007; 7th March 2010 at 05:30 PM. |
#16 |
I don't mean to be dense here so help me understand.
I don't have the Drive Select feature. Are you saying we can adjust the trans and engine via the Vag Com? Would this work similar to the ECU adjustments where you have more torque? My issue with the car is that I wish it had greater throttle push in first gear. |
#17 | |
I've not tried it on the road - and am away in New Orleans for 2 weeks....
#18 | |
#19 |
corectamundo. That's why I'm stunned. A superb find...
#20 |
Now we need someone to test and report
#21 |
Great stuff, thank you a lot C99 and others who have developed on the info.
Updated the VAG COM list on my sig too as a future reference.
#22 | |
#23 |
I tested it in the morning (for engine) and I think it works, I feel noticeable difference in engine response between Comfort and Dynamic.
#24 | |
#25 |
This is not substitute to an ecu tune from apr or giac. This changes how the engine responds to throttle and adjusts the shift points. If you're chipped and switch to dynamic, you see even MOAR response.
#26 |
Hey guys. First I want to say great job on these codes. Its been a great help to us S4 guys!
![]() I'm having some trouble and wonder if someone could help. I was able to get everything programmed down to the menu part. I unlocked everything but its still grey and not selectable. Ive changed 63-66 all to 4 as well I think it has something to do with the Byte 17, bit 7, change 0 to 1 coding When I do this it turns off my control lights off. My coding in byte 17 is 00011100 if I switch it to 00011110 it turns the consel control lights off. Any ideas? Heres what I have ![]() ![]() ![]() |
#27 |
Chris - told you to call me!
You're changing the wrong bit. Byte 17, bit 7, change 0 to 1 coding My coding in byte 17 is 00011100 switch it to 10011100 NOT 00011110
#28 |
BTW the coding has left the Audi Drive Select individual menu on ChrisMT79's car looking really weird: it should never display both Steering and Dyn. Steering at the same time because they are mutually exclusive... Also, it is showing both Engine (for manuals) and Engine / Gearbox (for automatics), which too should be mutually exclusive and never show both at once.
Obviously it is also showing extra items since only a car without dynamic steering, dynamic dampening and sports differential would only, at max, be able to control Engine / Gearbox (for automatics, Engine only for manuals) and Steering (on cars with servotronic).
#29 |
I think Chris has done something wierd. I'm trying to talk to him about the changes he made...
#30 |
I tried to enable ADS in concert radio. I first changed bits that need to be changed...and then channels 63,64,65 and 66. At that point i have to mention that i do not have Audi drive select, so i choose to set value 3 on all four channels. Coding accepted, but no menu appears in concert radio. Is that normal? (maybe it is, i don't know). Then fault scanning shows 2 faults, one is at centr electr (9) and the other is at 56 (radio).
1 Fault Found 03207 - Charisma Switch Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 212 Mileage: 20793 km Time Indication: 0 Date: 2010.03.11 Time: 18:19:00 1 Fault Found 03157 - Functionality limited due to Communications Disruption 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 247 Mileage: 20764 km Time Indication: 0 Date: 2010.03.08 Time: 17:00:14 Freeze Frame: Bin. Bits: 00000000 Bin. Bits: 00000001 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 Ok i think Address 09 normally pops-up fault due to no carisma. What about Address 56 (radio) ? Can someone recommend how to fix this? Overall i can not understand if there is any improvement...I could say i only saw a marginal difference in throttle response (even though ECU is chipped) and some improvement in handling? i really have to drive it more to be completely sure. i am confused... |
