The Drivers Network
Go Back   A5_OC > Audi A5 & Audi S5 Forums > A5OC Sponsors > Europrice
Thread Tools Display Modes
Old 23rd February 2010, 11:39 AM   #1
Europrice
Site Sponsor
Exclamation Quick "Spring is Coming" STaSIS Engineering Sale...
For the remainder of February I will be offering special pricing on all of the STaSIS Engineering gear for the A5 and S5 to A5OC forum members only! This means coilovers, sway bars, exhausts and big brakes all on sale right now...
"No more fading, higher heat absorption and dispersion makes for shorter stops turn after turn. Improved pedal feel, firm, confidence-inspiring brake pedal because of ultra-stiff calipers, differential piston sizing. No more warped rotors due to properly designed two-piece floating rotors. Pounds less than stock, less weight gives shorter stops, quicker acceleration, improved steering feel and handling. Compatible with ABS and traction control systems with brake bias designed to ensure ultimate gripping power. All hardware is included to ensure a quick and seamless installation."
STaSIS Engineering Mono6 370mm Big Brake Package - $3895.00 set - NOW $3399.00!
"The Ohlins dampers used in this kit offer extremely quick reaction time to driver input and wheel movements resulting in a smooth ride and unparalleled car control. Ohlins dampers provide extremely quick reaction to movement allowing lower damping forces and higher spring rates to be used. Without exhibiting the typical “harsh” ride associated with increased spring rates. Through extensive R&D, our engineering team has tailored the spring rates and valving to suit each vehicle, providing superior handling and better than OE ride quality. Ride height adjustable over a wide range to suit just your taste. The UHMW perch and bearing makes for easy adjustments by decreasing the friction between the perch and spring, eliminating spring “wind-up” under compression. The SL damper provides many of the performance features, and ride quality characteristics found in the Motorsports suspension at a terrific price."
STaSIS Engineering Ohlins SL Suspension - $2995.00 - NOW $2599.00!
"STaSIS Engineering’s 28mm Rear Anti-Roll Bar brings new levels of confidence inspiring control to Audi enthusiasts everywhere. Designed uniquely for the B8 chassis, the rear anti-roll bar stiffens the rear end to improve turn in and create a more balanced chassis feel. Reduce understeer, Increased stiffness of the rear end increases front end grip providing more responsive turn it. Better rotation mid-corner and increased lateral grip make this ARB a must have for any enthusiast. Decrease Body Roll, Improve Steering Response, Increased stiffness in the rear end reduces body roll and heightens steering response and feedback. The improved response allows you to hunt apexes turn after turn, all day long. This is the stiffer of two units and is designed for use with a firmer suspension such as the Ohlins SL. This bar can be used with stock suspension however it can cause the rear inside wheel to lift and cause more throttle-off oversteer than wanted for the average driver."
STaSIS Engineering 28mm Rear Sway Bar - $279.00 - NOW - $249.00!
This cat-back exhaust offers perfect blending of aggressive sporty tones when you want it and quiet cruising when you don’t, making this the perfect performance street exhaust system. Polished mandrel bent T-304 stainless steel. Quad double walled dual - 3.25” polished tips with laser engraved STaSIS logo will withstand tarnishing over many years. Expect a 10-15 TQ/HP increase with software.
STaSIS Engineering S5 Signature Series Cat-Back Exhaust - $1695.00 - NOW - $1495.00!
"This cat-back exhaust offers perfect blending of aggressive sporty tones when you want it and quiet cruising when you don’t, making this the perfect performance street exhaust system. Polished mandrel bent T-304 stainless steel. With use of S5 Rear Valence on S-Line A5 models (pictured) twin sets of double walled dual 3.25" polished tips with laser engraved STaSIS logo that will withstand tarnishing over many years. Expect a 10-15 TQ/HP increase with software."
STaSIS Engineering A5 Signature Series Quad Tip Exhaust -
"This cat-back exhaust offers perfect blending of aggressive sporty tones when you want it and quiet cruising when you don’t, making this the perfect performance street exhaust system. Polished mandrel bent T-304 stainless steel. Double walled dual - 3.25” polished tips with laser engraved STaSIS logo that will withstand tarnishing over many years. Expect a 10-15 TQ/HP increase with software."
STaSIS Engineering A5 Signature Series Tip Exhaust - $1395.00 - NOW - $1195.00!
***Inquire for the newly released A5 2.0t Signature Series Exhaust pricing and availability.***
Many items in stock and ready to go for your order, big brake packages ready to ship the 1st week of March, suspension components in stock and ready to go (limited availability) and multiple exhausts in stock right now!
Please PM or email for details or pricing: contact@europrice.us
*Please provide an address if you would like a total quote including shipping costs
Don't miss out this sale only lasts thru Sunday February 28th!
Thank you again,
.::Europrice::.
www.europrice.us
Europrice is offline   Reply With Quote
Sponsor - Register now for free to stop viewing this ad.
Old 2nd March 2010, 01:39 PM   #2
Europrice
Site Sponsor
Default
Extending the sale until March 14th! Decided I didn't give all of you enough time to get in on this sale, so those of you who were on the fence have two more weeks to get in.
So don't miss out this time!
.::Europrice::.
www.europrice.us
Old 9th March 2010, 12:55 PM   #3
Europrice
Site Sponsor
Default
Getting closer to the final close of the sale! Don't miss out and thank you for those of you who have purchased!
.::Europrice::.
www.europrice.us
Old 31st March 2010, 09:11 AM   #4
dolce A5
Default
What do the springs cost alone without the bar or coil overs?
dolce A5 is offline   Reply With Quote
Old 31st March 2010, 10:17 AM   #5
Europrice
Site Sponsor
Default
The springs are standardized size coilover springs, they would only work with this system. However if you have a STaSIS coilover and want to experiment with different spring rates you can.
Cheers,
.::Europrice::.
www.europrice.us
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
