Evening,
I've been searching around and all I can find is one american video clip on YouTube that shows the A5 Cab being retracted with just one click on the roof button in the console. Then 1 click to bring it back to cover the car again. In the A5 Cab's Ive test drove recently you have to hold the button down until the roof is completely finished doing its business before letting go, but this shows different. I can only assume this is an aftermarket mod or a VC change? Anyone any ideas? Surely it would be much better to do it this way, as I cant think of a valid 'safety' reason to "hold" the button to complete the job? Cheers Andy
A5 Cab S-Line VagCom: Horn Beep on Lock / VIM / Splash Screen / Battery Gauge / Lap Timer / Needle Sweep / DAB Radio Signal / MMI Hidden Menu / Ambient Light / Washer Fluid Warning / Disable SeatBelt Chime / Voice Control / Change of Default ADS choice (Individual) |
If it was one click you wouldn't be able to stop it once it started, thus preventing the easy way to clean the inside of the rear window.
Mulski Current - A5 Cab S-Line Metallic Silver-Black Hood (2.7 TDI Multi); 19" 5 Segment; MMI3G Tech Pack; Flappy Paddles; Bluetooth; Heated Seats; Interior Light Pack; Hill Hold Assist; Cruise Control; Folding Mirrors; Dimming Mirrors; TPM; Xeon-DRLs-Rear LEDs VAG-COM'd: Non-Dimming DRLs/Voice Command/Ambient Lighting/Rear DRLs/Lap Timer/Needle Sweep/Mirror Tilt/VIM/Splashscreen/Battery Gauge/Lock Beep. 2nd Audi - A6 (2.7 TDI SE) Phantom Black; 1st Audi - A4 (1.9 TDI SE 130) Met Silver. |
#3 | |
#4 | |
The only mod I would like is to drop the windows all the way down as part of the roof retraction process. That would be good. By default they either stay partially open or return to the closed position if you hold the button beyond the beep!
Chris. Current (01/03/2010): Audi A5 Cabriolet S-line - 2.0TFSI - 6 Speed Manual - Quartz Grey - Black Roof - Symphony Radio + DAB - Interior Light Pack - B&O - Inchcape Exterior Detailing, Alloy Detailing, and Interior Protection Actual Average: 33.46MPG Last: Audi A4 Cabriolet (2004) - 2.4V6 Sport - Multitronic - Silver/Black |
#5 | |
Surely the windows could be VC'd.... ? A.
#6 |
I’d like a VCDS coding for one touch, handy when you’re in the car – although I agree with the advantage from a cleaning perspective of so a MMI On/Off would be good.
My MkII TT had one touch drop, but hold for close – guess that was a safety feature.
Currently: S5 Cabriolet, Phantom Black, B&O Sound System, DAB Radio, Phone prep high, Tech' pack with ACC, Parking Advanced, TPM, Advanced Key, Adaptive Lights,Comfort Pack, Heated Front Seats, Drive Select full, & Sports Diff. |
#7 | |
or maybe I'm just being a picky plonker. ![]()
#8 |
This place do a 'module' for One Touch Open and Close, but its only (at least so it seems) for the A4 Cabriolet.
![]() http://www.reinhold-engineering.de
#9 |
Don't speak too soon Andy
https://www.wit-usa.com/sms/shop/ind...ew&idlistpos=2 and the installation guide. Seems simple enough. http://www.wit-usa.com/sms/db/smartt...tall_A5/en.php with lots of other options... (sort of) Result.. but its 300Euros...
#10 |
I'll investigate...
#11 |
#12 | |
2010 S5 Cab./Premium+/Quartz Gray/Black-Tuscan/Nav./B&O/Sport Diff. |
#13 |
s5cab10.
Indeed you a right sir. I found it last night. see up this thread ![]() Do you think its a worth while mod then as someone who has done it? Cheers Andy |
#14 |
No luck so far. Found loads of VCDs for everything but lowering the windows all the way when lowering the roof...
The only possible solution would be to drop the windows first using the center console switch. Then drop the roof and release the switch when the system beeps (i.e. the roof has completed the process). Not ideal but...
#15 | |
https://www.wit-usa.com/sms/shop/ind...ew&idlistpos=2 link may not work and you may need to traverse the site manually. Some Features: Separate window control - Raise and lower the windows separately by remote without activating the top." One-Touch power convertible top - "One-Touch" convertible top operation allows your top to open or close automatically. Chirp-signal function - When locking and/or unlocking the car, the horn sounds briefly if desired. Hazard Signals - Optionally the hazard blinkers are activated while top is operated from the remote. Designed for: Audi A5 Convertible Model Year 2009+ E13 Certification: E13 10R - 03 10070 Standby Power: < 0.1mA InstallAID™ LED: YES Seems good, but 299 Euros A. EDIT: Its on ebay too:
A5 Cab S-Line VagCom: Horn Beep on Lock / VIM / Splash Screen / Battery Gauge / Lap Timer / Needle Sweep / DAB Radio Signal / MMI Hidden Menu / Ambient Light / Washer Fluid Warning / Disable SeatBelt Chime / Voice Control / Change of Default ADS choice (Individual) Last edited by andyhud007; 11th March 2010 at 04:00 AM. |
#16 |
I read in some thread that if you have the advanced key there's an ability to drop the top with the remote. This ability is what's most appealing to me. If this module enables that for those without the advanced key then it's worth it. The one I installed works great!
#17 | |
NL-S5 Cabrio Brilliant Black|Waxoil|Mustang Brown leather|Comfort seats/ventilation|Neck-heating|Heated front/rear seats|Memory seats/mirrors|Silver Headlining|RVS Inlay|B&O|MMI 3G High|Nav Plus|AMI|Freecom XXS 320Gb HDD|DVD|TV/Radio|Bluetooth Plus|Xenon Plus|LED rear|Adaptive Light|High-Beam assist|Light Pack|Parking Advanced|Advanced Key|Adaptive Cruise|Side Assist|19" RS6 wheels (PQ6)|TPM|Dynamic Steering/Suspension|Sports differential|Hold assist|HomeLink|Track & Trace|Ski-bag|Storage Pack |
#18 | |
may look into this mod once I get the car... A.
#19 | |
#20 | |
Tim
S5 Cabriolet Ordered 30.12.2009, Wk15, Collected 01.05.2010 Lifetime Economy: 4118 miles | 14.8 mpg (real) Consecutive days with the roof down: 83 Sepang Blue | Spectral Silver | S-Tronic | 20" 7 Arm Double-Spoke Alloy Wheels | Tech Pack | B&O | Advanced Key Convenience Pack | Bluetooth Interface | Heated Front Seats | Adaptive Lights | High-Beam Assist | Hill-Hold Assist Parking System Advanced | Tyre Pressure Monitor | Drive Select | Sports Diff | Damping Control |
#21 | |
So I did not bother...
#22 |
Is this a 100% correct and applies to the uk type
Audi A5 3.0 tdi sport |
#23 |
Tony, as PM, but for others to see, I 100% guarantee that the UK Advanced Key model opens remotely by a triple press of the unlock button and then holding it.
#24 |
thanks for the pm
#25 | |
The exact reverse for closing the roof. A. |
#26 |
Any chance someone can please provide those of us in the USA with the VAG-COM coding to enable the key fob to put the blasted top up and down? I've coded the windows to do this but the top would be a nice add. Thanks!!
#27 |
if you've ever pulled into a multi storey car park, parked up and proceeded to raise your roof and realised as it goes up that it's going to hit the ceiling you'll really appriciate the 'hold button' anyways is life that bad having to hold a button for 16 seconds or whatever!
#28 |
I've got in the habit of doing it whenever without thinking, normally as I leave my garage I do it while maneovering out, or when I get home it's coming back down when I'm parking.
Although if you have a passenger, they love doing it!
#29 | |
![]() ![]() ![]() Cheers
