The Drivers Network
Go Back   A5_OC > Audi A5 & Audi S5 Forums > A5 & S5 Topics
Thread Tools Display Modes
Old 9th March 2010, 06:53 AM   #1
andyhud007
Default MMI 3G AMI Connector Lead Question and SD Card query.
Hi Guys
Quick question. I've ordered the MMI 3G Tech Pack with AMI for my A5 Cab and wondering what leads you get with the AMI connector?
Do you get all the connectors and one lead where you can just change the plug on the end to suit the device you want to connect? or do you just get say (in the UK perhaps) just the iPod Connector?
What if I want a Mini USB connector like this:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=170392370241
Do I have to buy it separately?
Also, does anyone know the max size of SD card the MMI supports?
Ta!
Andy
A5 Cab S-Line
VagCom: Horn Beep on Lock / VIM / Splash Screen / Battery Gauge / Lap Timer / Needle Sweep / DAB Radio Signal / MMI Hidden Menu / Ambient Light / Washer Fluid Warning / Disable SeatBelt Chime / Voice Control / Change of Default ADS choice (Individual)
andyhud007 is offline   Reply With Quote
Sponsor - Register now for free to stop viewing this ad.
Old 9th March 2010, 07:17 AM   #2
zee007
zee007's Avatar
Default
I only got the IPOD cable and have recently bought a mini USB cable.
I've used up to 32Gb SD cards without a hitch...
- Zee
His arrived 25 Feb 2010: 2010 Audi S5 | Sprint Blue | Alcantara | Black Optic | B&O | BBS | Eibach | B&B | Stasis | H&R | K&N | PIAA | E-codes | OEM mods | Tint
Hers arrived 29 Dec 2009: 2010 VW Golf | TDI | Black | Black | OEM Mods | Tint
Been there, Done that: Silverstone F1 circuit, Spa Francorchamps, Donnington Park, Virgina International Raceway and the mighty Nürburgring
zee007 is offline   Reply With Quote
Old 9th March 2010, 07:34 AM   #3
andyhud007
Default
zee07
Many thanks for the quick response.
weird, does that imply you dont get any say in the lead you want/need and its just iPod only? I guess the brochure implies iPod only its description for the UK market... hmmm
As for SD card size... cool. that is plenty then!
Andy
Old 9th March 2010, 01:21 PM   #4
Cosmicblue
Cosmicblue's Avatar
Default
You get two leads, one for the iPod and another with a female USB end.
The iPod integration works really well, only limited by the iPod's OTT way of indexing songs and picking up when more than one artist is named on a single track - serving to break the album up into pieces if you are searching by Artist. It works well if your search by album instead though, its annoying!
I'd rather use an external USB disk but 3G MMI applies a 4,000 song limit - lots yes but less than many have in their music collections.
A5 2.0TDI 170 PS S-Line, Cabriolet. On PCH. Aruba Blue and Blue Roof, Black Alcantara with Silver Stitching, Heated Seats, Auto Dimming Interior Mirror, Servotronic Power Steering, Interior Light & Technology Packs, Tire Pressure Monitor, Parking Plus, Folding Mirrors, B&O, Bluetooth Phone prep, 10 spoke 18" alloys. Road Angel Pro Connected
Cosmicblue is offline   Reply With Quote
Old 9th March 2010, 01:30 PM   #5
andyhud007
Default
Cosmic,
This was exactly my thinking. I have a 160GB WD laptop drive with a mini USB connector on it and wanted to hook that straight in, but if there is a 4000 song limit I may just use the 10GB inside the MMI and/or SD cards.
No VAG-COM change to increase that limit that we know about perhaps?
Andy
A5 Cab S-Line
Old 9th March 2010, 08:39 PM   #6
Alkivar
Alkivar's Avatar
Send a message via AIM to Alkivar
Default
Originally Posted by andyhud007 View Post
Cosmic,
Andy
i've got a 500gig hard drive... the 4000 song limit is PER FOLDER... not per drive... but i'm 2G MMI.
Alkivar is offline   Reply With Quote
Old 9th March 2010, 09:49 PM   #7
loc
Default
What cable comes standard depends on your market, usually nothing from factory itself but dealers may/will add a cable, or not, depending on market...
Note that the 32GB cards supported are SDHC cards, not SD - slight technical difference (no matter to the user though, just get the right type of card - not that there are such large SD cards anyway I guess). SD are supported up to 2 GB and some 4 GB (like Transcend 4 GB SD) work too.
AMI lead part-numbers here, note that MMI 3G iPod cable is newer/different part number than the old MMI 2G iPod cable was - the new has a blue grommet on it:
AMI (Audi Music Interface) part numbers / Notes on retrofitting AMI
http://a6retrofit.tripod.com/articles/a4a5amiparts.html
loc is offline   Reply With Quote
Old 9th March 2010, 11:30 PM   #8
andyhud007
Default
Loc
Understood. Cheers for the info.
I only have SDHC cards so all good there. Be interesting to see what my UK Dealer will offer as a lead. Hopefully at least 1 of them having just spent that much on the Tech Pack!
Andy
A5 Cab S-Line
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
